Go to Post P.S. I'm not boring! - Matt Krass [more]
Unread 09-04-2009, 14:25
davidc10 davidc10 is offline
FRC #0423
Rookie Year: 2007
davidc10 will become famous soon enough
Problem Debugging as a Stand-Alone project
I have not been able to debug a stand-alone, run-on-startup, robot project through the menu Operate ->Debug Application or Shared Library. (Not the standard debugging, which I have no problem with).
I think I've followed all the instructions: debug enable in build, vi server TCP enabled on the cRIO - set to port 3580, etc., re-built, deployed all, correct ip, firewall off to be safe...). The PC sends a request for a list of debuggable apps, but the cRIO won't respond to the request.
The message is "Failed to lookup debuggable applications or shared libraries", which means no response from the cRIO. I have no problem getting the System Manager to connect - which also uses port 3580. (I don't try to do both at the same time.)
I've posted on the FRC forum and NI forum, but can't get any answers as to whether this feature is disabled on our system, or whether I'm missing a setting.
Thanks,
David
Unread 09-04-2009, 15:21
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Problem Debugging as a Stand-Alone project
I don't recall seeing your posts either on the FRC Control system forums or the NI FIRST community? Perhaps you could post links to those posts.
A while back, I tried the same thing for about 5 minutes, then gave up. Good luck getting it working.
Unread 09-04-2009, 15:29
FRC #0423
Rookie Year: 2007
Joe,
Here are both links:
http://forums.ni.com/ni/board/message?board.id=170&message.id=399315&query.id=37 3608#M399315
http://forums.usfirst.org/showthread.php?t=12538
David
Unread 10-04-2009, 17:05
Rookie Year: 1997
You might have better luck with the NI FIRST community rather then the plain NI forums.
cRio Stand-alone Image Tool Vikesrock FRC Control System 3 29-01-2009 19:38
Problem with deploying a stand-along application windell747 NI LabVIEW 4 27-01-2009 07:24
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
Problem Compiling Project MikeDubreuil Programming 3 10-02-2007 17:46
Am I alone in the universe? Madison Chit-Chat 4 22-02-2004 20:34
