Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 10-04-2009, 10:52
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
1 Red Ring on XBOX 360?
Hello,
I turned on my friend's XBOX and turns out that he has 1 red ring. For example, the red ring of death has 3 lights on, but this type only has 1 red light on.
I'm trying to figure out what the problem is. Some websites say it's not plugged into the TV and some say that it's a manufacturing issue.
Please let me know if someone here has dealt with this problem, or knows about it.
Thank You.
1648: 2013-2014
5283: 2015
Unread 10-04-2009, 11:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: 1 Red Ring on XBOX 360?
TTL,
This may simply be an issue of over temp on the microproc. If the box is still in warranty then opening it is not an option. There is Microsoft tamperproof sticker internal to the box that needs to be removed for entry into the box. The two fans suck a lot of dirt into the box which clogs the heatsink. Unfortunately, self diagnostics are not a big deal in Xbox so there could be something wrong with either the cable or the connector. If the box doesn't get moved and it lives on the ground or inside a cabinet, suspect the dirt. If it moved a lot, suspect the connector/cable.
There is a lot of info on the net about error messages and fixes. Choose wisely...
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-04-2009, 12:46
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Check to make sure that both the power and AV cables are securely connected at the Xbox side. I had this problem at one point and it cleared up after checking those connections.
Xbox 360 controller LabView CJBrick General Forum 12 17-12-2008 13:58
xbox 360 controller installation kuelin Technical Discussion 17 07-01-2008 19:43
XBox 360 Joe Matt Chit-Chat 83 29-11-2005 15:18
Xbox 360 + Walmart + Demo? Conor Ryan Chit-Chat 7 20-10-2005 20:29
Xbox 360 zdeswarte General Forum 1 11-05-2005 14:53
