Go to Post I would much rather educate the audience than dumb-down the game. - dlavery [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 11-04-2009, 17:55
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
How to force break a loop
Not a problem, just a question:
In my autonomous independant VI, I use a while loop, and have the "false" constant tied to the conditional terminal. (It's set to stop if true)
From what I can tell, the robot should be stuck in Disable once the DS switches to teleop, because the code should be stuck in autonomous (it doesn't look like there's anything to stop the autonomous code and allow Teleop to proceed).
How does Labview force that loop to break execution?
Or am I using a very inefficient coding technique in that Labview doesn't actually stop the autonomous code, it just ignores it?
I'm not running into any problems, it just seems like a very useful thing to know.
-- Marshal Horn
Unread 11-04-2009, 17:58
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Rookie Year: 2007
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Re: How to force break a loop
if you look at the get robot mode virtual instrument you can find where it switches between modes. before it switches out of autonomous it uses a labview control vi to stop the independant vi execution.
[edit]
the loop itself isn't stopped nor paused, the whole independant.vi is closed/stopped.
[/edit]
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 11-04-2009, 18:24
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
normally to "pause" a loop without terminating it (which would imply that you cant start it up again), youd use a sync vi to have the loop constantly waiting for that vi to return something (like a semaphore). the reason the loop "pauses" is because a loop is programmed to not continue until all inner vi's have outputted something
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 11-04-2009, 19:28
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
[edit]
[/edit]
So that's why Begin.vi requires a VI reference to the autonomous mode?
-- Marshal Horn
Unread 11-04-2009, 19:30
What Time Is It?
Rookie Year: 2007
basically yes.
Unread 12-04-2009, 08:14
The puzzle has been solved. I'll just add that aborting running VIs is not something you should do on a regular basis. We are doing it here to make the framework simpler to use. The normal way of exiting a loop is for the code in the loop to say "I'm done". It can include info from anywhere else in the program to make that decision.
Using the Run and Abort methods on a VI is a way for you to spawn and kill a task similar to an OS thread.
Greg McKaskle
How to tune a PID loop? steve d Programming 3 11-02-2007 20:49
Need a little help with how to break out of the box amateurrobotguy Programming 6 16-01-2006 12:56
How long is one stamp loop yangotang Programming 3 23-01-2003 20:36
How much force to push the ramp? archiver 2001 1 23-06-2002 22:44
How Can You Make A Closed Loop System???? GRR_340 Pneumatics 6 21-03-2002 12:27
