Go to Post Viva la geek! - Andy Baker [more]
Go Back   Chief Delphi > Other > VEX
Unread 14-04-2009, 20:49
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
[Vex] Spontaneous channel switching/dying
We are having an unusual problem with our vex elevation robot. Controls from Rx1 work fine. However, for about one boot out of every four, about 30 seconds after teleoperated mode begins, signals from Rx2 begin to undergo a bizarre, repeated, pattern:
Channel 5 (controlling motors 5 and 6) does not work
Channel 4 (controlling motor 7) instead controls motor 8
Channel 3 (controlling motor 8) does not work.
After about 45 seconds of this, the robot returns to normal.
Rx2 Light remains on at all times, and no code error light flashes
This problem has never occured under tether, but its occurence is inconsistent enough that i could believe that this is a coincidence
Any suggestions as to why this might be/how to solve it?
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-04-2009, 23:49
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Team Role: Mechanical
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: [Vex] Spontaneous channel switching/dying
Are you stalling motors? The VEX controller will start to do weird things if the battery voltage drops below 5volts. This usually occurs in the controller restarting, often in auto mode in the middle of a match.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 15-04-2009, 16:17
NShaffer829 NShaffer829 is offline
FRC #0829 (Digital Goats)
Team Role: Driver
NShaffer829 has a spectacular aura aboutNShaffer829 has a spectacular aura aboutNShaffer829 has a spectacular aura about
Our robot had similar issues but we found that to fix it all you normally needed to do is turn your control off and on and everything worked fine.
Nick
Vex Powerpack (quick dying battery) ddmflame General Forum 9 03-08-2006 02:30
dying internet Denman IT / Communications 4 26-06-2005 13:33
Switching the Channel for Competition Matthew_H Control System 28 13-04-2004 14:24
Team Force Website Dying Petey Website Design/Showcase 20 02-03-2004 12:16
Dying Breed! archiver 1999 0 23-06-2002 22:16
