Dashboard
Could someone tell me how you set up the dashboard for the axis camera? We didn't use it when we competed, and I don't really know how to set it up so that I can get live feed from the axis camera.
Re: Dashboard
Can you elaborate on what problems you're having after Greg's response in your previous thread? http://www.chiefdelphi.com/forums/sh...ad.php?t=76128
Re: Dashboard
I need to check on things. I switched laptops and I'm thinking that it's confused with the data. I'll see if it continues after I sort things out.
Re: Dashboard
I've decided I'd go back to the other laptop. It's not worth the time sorting things out even though I could work faster on a different one. Do the dashboard defaults automatically give you live feed, or do you have to tweak things a bit, and if so, how would I go about that?
~CHSboy |
Re: Dashboard
The robot template code automatically waits for a TCP session to send data to on a dashboard. When the dashboard connects to the other side, the images will start flowing.
The dashboard has a button on its lower left corner that controls the display. I don't remember whether it defaults to on or off, but that is all that is required to control it. Greg McKaskle |
| Dashboard | Eugene Fang | Programming | 4 | 24-04-2007 21:37 |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 02:04 |
| 2004 Dashboard Protocal vs 2005 Dashboard Protocal | Kyle T | Programming | 4 | 14-03-2005 22:19 |
| Dashboard | Kevin Karan | Programming | 60 | 19-03-2004 21:53 |
| dashboard | archiver | 2000 | 1 | 23-06-2002 23:06 |
