Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 15-04-2009, 15:07
CHSboy CHSboy is offline
FRC #2153
CHSboy is an unknown quantity at this point
Pneumatics
How do you set pneumatics up in labview if you want to just have like an on/off switch?
Unread 15-04-2009, 18:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Pneumatics
The question seems to assume a context that isn't obvious to me. Pneumatics on an FRC robot is on/off by nature, so I'm not sure what the issue is.
Maybe if you described more about the on/off switch, and what you want to happen when it is turned on or off, it would be easier to give a useful answer.
Unread 17-04-2009, 15:03
FRC #2153
Re: Pneumatics
Just need it to turn work a pneumatic cylinder. Sorry for the confusion. Didn't think about that part when I asked the question.
Unread 19-04-2009, 13:15
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Re: Pneumatics
The solenoid VIs are in the Solenoid subpallette, inside the functions pallette at "WPI Robotics Library" » "Actuators" » "Solenoid"
-- Marshal Horn
Unread 20-04-2009, 09:35
FRC #2153
Re: Pneumatics
Alright. I'll see what I can figure out from there. I'll post again if I have any problems. Thank you.
~CHSboy
Pneumatics????????? RoboPunk_994 Programming 1 31-01-2008 14:16
Pneumatics? falconmaster General Forum 6 19-01-2007 11:25
pneumatics CD archiver 2000 2 23-06-2002 22:46
Pneumatics archiver 2001 1 23-06-2002 22:36
