Go to Post This season, I learned that I will need a whip next year for keeping the electronics and pneumatics groups on schedule. - Yan Wang [more]
Unread 21-04-2009, 09:57
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
pic: Sliding Wheel Chain Tensioners
Unread 21-04-2009, 10:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Sliding Wheel Chain Tensioners
That's a neat idea!
I do see one potential problem with it...since it's a square tube, and there is nothing surrounding the bolt, the tube will crush before you get the bolts tight enough to securely clamp the tube in place so it won't be slid by chain tension under load.
Adding a 3/4" long spacer around each bolt might help.
Unread 21-04-2009, 10:21
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
You could also mill the blocks from either solid aluminum or maybe even delrin to avoid the crushing problem. That is an awesome Idea and I think there would be a pretty awesome market for such a thing.
Mentor 2415
Unread 21-04-2009, 14:30
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Rookie Year: 2007
I hadn't considered marketing anything, but your comment made me think, if it were to be marketed, teams wouldn't want to mill out their kit chassis. Then I realized, the slots could be made in the piece of extruded aluminum, and not in the chassis itself. It seems to me that this would be a nicer way than my original design because a team could try it without doing anything to their chassis, and take it out later if they wanted. I'll try to design this other way in CAD as soon as I get the chance and a post picture.
Also thanks for the comments. Washers should definitely be there, and tubing around the bolts is also a very good idea.
Mens et Manus
Unread 21-04-2009, 18:38
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
I used a similar method in 2003. But be careful
the slots are in the same direction that the pull of the chains will be..
So when the motor pulls it could slide the screw to the loose side. It will be difficult to tighten the screws enough to keep this secure. You might add a second screw (and spacer) to each side directly in the slot.
If you really jam your motors on... (in quick acceleration or in changing from one direction to the other....) you can put a great deal of force in the same direction as the slots...if one side is less tight than the other you will get misalignment and you will throw chains...
You might want to consider something that moves the motor in and out perpendicular to the pull of the chain... this would not have as great a tendancy to loosen. There are many ways to keep tension on chains..
I am sure if you do a search you will find others.
Testing is the key... keep track of how tight you tighten the bolts... (use a torque wrench) Don't count on tightening as tight as you can without being able to know how tight that really is.... (this can vary between people and between situations...) Reproducibility and testing the system under these shock loads will be necessary for you to see if this will work for your situation.
Just be wary of the nature of this design... As I said... back when we were using drill motors and a plastic transmissions this method caused us a great deal of grief...and matches with our robot traveling in a circle on the field while dangling a chain...
Good luck in your design!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 21-04-2009, 10:26
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Originally Posted by squirrel View Post
That's a neat idea!
we solved that problem by adding a piece of PVC pipe as our space for a similar application. It worked quite well.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 21-04-2009, 12:00
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
is that really a problem because of the fact that all the tightening is happening on the c channel and not the square channel
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 21-04-2009, 12:09
MrForbes's Avatar
AKA: Jim
Yes, it is really a problem. Bolts work best when they are clamping something solidly between them, so they can squeeze the part very tightly. You could try it and see what happens, experiments are a good way to learn the effects of certain design principles.
Unread 21-04-2009, 13:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This will work if you take special care to ensure the axle stays perfectly perpendicular to the chassis rails. If you don't, your sprockets will be misaligned and the chain will pop of while driving.
GitHub
Unread 21-04-2009, 13:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Adding in a lateral screw adjustment component can help avoid teh need for clamping forces. Look at the rear axle of most chain driven motorcycles. See if you can come up with something similar to that, and then clamp load is nearly irrelevant.
Unread 21-04-2009, 13:38
MrForbes's Avatar
AKA: Jim
The lateral tension screw is a great idea! but I would still add a spacer to prevent crushing the tube and C channel.
Unread 21-04-2009, 18:41
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
294 did this with the 05 frame.
Similar design with lateral screw tensioners and milled from solid.
Unread 21-04-2009, 20:53
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Rookie Year: 2000
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Keep it simple. A solid wooden block which fits snugly inside the square tubing will keep it from crushing. You can make it a mechanical tensioner by sliding an eye bolt over one of the lock down bolts and running through a fixed point.
Unread 21-04-2009, 21:06
AKA: Sean
If you were truly looking to market and sell the tensioner I would push for it to be milled out of aluminum. This would eliminate having multiple pieces of tube or what not to avoid crushing the square tube, and if you thread one end for say 1/4-20 then whoever bought the tensioner could simply use the appropriate sized 1/4-20 bolt as a tensioning device.
Mentor 2415
  #15   Spotlight this post!
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
That might work a bit better if you had two shorter slots, one for each of the bolts, and you limited the play as much as possible. Use it to take up the slack in a chain or belt, but don't use it to reposition the wheel significantly. (So you'd only need, at most, one chain or belt pitch worth of play.)
Also, I assume this is intended principally for a dead axle system. If not, you're going to have a hard time rotating the shaft, if there's any misalignment.
And while you're at it, you probably want to use some flat washers under the bolt heads and nuts, so that the tightening process doesn't embed the hexagonal surfaces into the chassis rails. This assumes that you're going to use nylon locknuts and will design the system so that you can apply significant bolt tension without crushing the channel.
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: 1281 light tensioners VEN Extra Discussion 4 10-02-2008 15:53
pic: team 1029 more tensioners... bjimster1 Robot Showcase 1 11-02-2007 16:26
pic: Chain and Back Wheel System hockeystud91 Extra Discussion 9 20-01-2007 17:54
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
