Go to Post Although you will see lot's of people complain about parts (sometimes that includes me) all of us are held to the same constraints. That's what makes this so much fun. - Al Skierkiewicz [more]
Unread 24-04-2009, 20:31
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Questions about crab/swerve drive.
Originally Posted by BenX02 View Post
I have been thinking of the wiring, how might you go about doing the wiring for that? I'm trying to figure out a way so that they don't get wrapped around.
Thanks for the help.
Slip rings. They're these little devices that allow electronic stuff to turn in full circles without twisting wires. Or coaxial-style--then there won't be anything electronic other than maybe an encoder or so on the modules.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 25-04-2009, 10:55
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
It is good to investigate different drive types but as Eric has pointed out, don't dedicate yourselves to a system that will be less than adequate for next year's game. We do not decide on a drive system until well into the first or second week. It is strictly determined by the game and the playing surface(s). Our modules have the motor and gearbox built right into the module and wiring is run down through a hollowed out top (vertical) axle. Rotation is limited to 360 degrees or less so wrapping up the wiring is not a problem. Automated machining makes things easier to assemble but is not totally needed. Don't forget to add a bottom bearing surface to prevent the module from binding when it is hit from the side or in turning at full speed. Globe motors have more than enough torque to turn two wheel modules at a time when used properly.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-04-2009, 15:05
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
The slip ring idea sounds great but aren't the extremely expensive?
Were also looking into building a crab/swerve frame in the offseason here to try and figure out how to build one should we need to for next year.
One of my biggest questions was how do teams that do coaxial crab run the wires down to there encoders in the actually swerve module? without the slip ring idea above i would think they could pretty easily get wound up around themselves and one of the advantages to the coax crab in my mind would be to not have to limit your self to a range of motion.
Unread 26-04-2009, 15:22
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
You put the encoder in the gearbox, so they never spin. you dont need them on the wheel module.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 26-04-2009, 16:12
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
The ones McMaster sells are at least $550 each. They're also huge--that particular one is 10 1/4" diameter.
I'm fairly certain that there are cheaper ones out there (and smaller); try an electronics specialty store.
Past teams:
Unread 26-04-2009, 18:22
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
We wanted a crab drive this year and due to weight constraints we just used front crabdrive, which worked very well once we got the rear wheel programming worked out.
The slip ring idea is very cool but a bit exotic. We built longer shafts for our cims with banebot 16:1 transmissions and mounted our motors directly on top of the drive. The motors do not turn (other than the shafts) so no wire twisting. We only built our shafts because Banebot was out of their longer shafts and we had the ability, so that worked out for us. We made everything modular so we could switch a drive in under 5 minutes.
To be honest, the "go to team" on crab drives is 118, the robonauts, and they are really happy to share what they know and how they do it. Their system allows them to use 1 to 4 cims and depending on the game they change the number every year. They had a display at the championship of their many evolutions ( very interesting stuff ). I'd look them up and drop them an e-mail.
The ONE and only drawback is that it is a bit complicated, as you would expect. They only lost the Houston regional last year (2008) because a drive failed at the last match of the finals and they couldn't replace it in time. (the reason we made our drive modular.)
Their mentor, Lucien, is a really great guy so if you really are interested, he's always willing to help out.
Ours is an "economy" drive but if you're interested in our ideas I'll be happy to post the system... I just need to get back to the robot... AFTER I crash for awhile... (it's been a LONG season!)
Good Luck!
Steve
Unread 26-04-2009, 18:37
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
It depends what kind of crab drive you are looking to do. If you are thinking Coaxial then 118 is definitely the team. However if you are doing a pod design with the motors in the modules then teams like 111 or 71 are better ways to go. Another exotic design is the Martians, 494 and 70 had them only anchored on wheels that were similar to what you would find in a drawer slide and turned by cabling that you would find in a bike, a very different and reliable solution that they innovated.
Unread 26-04-2009, 18:24
AKA: Chad
I seen the mcmaster one's but didn't even look at the size after i seen they were over the 1 item can be no more than cost factor.
Idealy you would want a through bore type i think so that you could do the coaxial setup with it. And If I'm right about the US Digital encoders they are a 4 conductor.
So anyone know where to get a 1/2" ID through bore 4 conductor slip ring and keep the cost down on it. Most of the ones i've found searching show them being able to handle RPM's in the hundreds which would never happen.
Unread 26-04-2009, 18:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Chad, if you are going with coaxial swerve there is really no reason to put the encoder on the rotating part of the module. Put the encoder further upstream and toss out the slip ring altogether.
Unread 26-04-2009, 19:19
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
If you can get 360 degrees, then I would say that is more than enough. My team's swerve can do approx. 720, but we found it useless and limted it to about 200ish. Once you turn them more than 180 and go forward, it's the same as turning the the other way as much and you would have passed 180 then powering backwards.The other thing is that you don't necessarily need encoders. This year it was pretty much a necesity because of traction control, but there are games where you can get by fine without them. I would design it assuming you need them, then maybe evaluate whether you need them when the game comes out. If you have coax anyway, you could put the encoders outside of the modules where your motors are, then figure out the speed based on gear ratios.(this year was a little different than most because of slipping).
Unread 26-04-2009, 20:00
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
Anyone know of a good supplier of pots and what type would be needed? Since pots can only go a fixed distance, what would a setup be like?
Unread 26-04-2009, 20:13
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I'm seeing an awful lot of people jump on the swerve guru bandwagon recently, and I'd to say something about that.
Before you hand out advice that someone may take as 100% perfect, think for a moment, do I REALLY know what I'm talking about? Can someone take my words, act on them, and be satisfied with the results?
Successfully using a swerve this year was a challenge, but also one much less so than on carpet. Most swerve designs I have seen this year would probably result in severe damage to the modules/turning shafts if they had been used on carpet.
Since I doubt we'll be getting anything other than carpet, that's what a new crab should probably be designed around.
Unread 26-04-2009, 21:58
Rookie Year: 1997
What application do you mean? If you mean speed encoders, the banebot encoders that fit on the transmissions is a very easy solution (http://banebots.com/pc/ELECTRONICS/EN-G0561-KT).
If you mean a position sensor, USDigital has a great absolute encoder that we used to link our left and right side drives together so we didn't have a chain across the robot. (http://www.usdigital.com/products/en...ary/shaft/ma3/)
USDigital also has rotary encoders that you can use with a wheel for floor speed if you are looking to do some traction control.
Ok USDigital IS pricey but I can't argue with how easy they were to use (a simple analog signal) and reliability. I think they are worth a look.
Steve
Crab Drive Questions craigboez Technical Discussion 18 13-01-2009 21:35
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Simple Swerve/Crab Rob2713g Technical Discussion 4 20-03-2007 19:00
Swerve/Crab Rob2713g Technical Discussion 5 12-11-2006 22:05
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
