Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
Unread 24-04-2009, 17:43
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
Rookie Year: 2007
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Win32 Hooks
For educational purposes/fun I've been messing around with some Windows work. I'm working with hooks (a keyboard hook to be specific), and I want it to work on a global level. According to this MSDN article the hook procedure has to be in a seperate dll. I've done this, and then called SetWindowsHookEx() as instructed here. idHook is set to WH_KEYBOARD, lpfn is set to the pointer to the hook procedure (loaded from the dll using LoadLibrary() and GetProcAddress() ), hMod is the handle to the dll, and dwThreadId is set to 0 (as is required to make the hook global according to the site). However, when I run it (and I've confirmed this using breakpoints), the hook only catches keyboard messages to the window that launched it. It works only on the thread level, and not globally. Any help would be greatly appreciated, as I don't know where I've went wrong. Everything else works perfectly. Attached is the code.
File Type: c keyhook_dll.c (901 Bytes, 150 views)
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
win32 dialog help Chris Bright Programming 10 30-12-2004 00:17
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Win32 API Port Connection Help Raven_Writer Programming 3 17-01-2003 14:23
Win32 Dialog Help Raven_Writer Programming 2 12-01-2003 09:37
