Go to Post Let me tell you, the scariest day ever was the day that I realized since I am a mentor, people actually take my advice and I should be careful of what kind of advice I give. :ahh: - Elgin Clock [more]
Unread 05-27-2009, 12:27 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Battery powered DS help
Originally Posted by J-Mech View Post
Well the fuse would protect against a device failure. So it would make a difference by protecting the router.
No.
Fuses do not protect devices. They protect wires from a device failure. Note that the only way to blow a fuse is to draw too much current. The only way for the router to draw too much current is for it to fail. A fuse cannot protect the router from itself.
A fuse might protect against the application of too high a voltage, but only if the device's power input was designed to survive overvoltage and to draw lots of current in the process.
Unread 05-27-2009, 03:00 PM
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Originally Posted by lcoreyl View Post
Hmmmm... just lost SECOND router using battery power. I think we are going to start using fuses; I would recommend the same to you...
Anyone else lost a router?
We lost a protective switch earlier this year. We were using a cellphone power supply with the correct voltage rating, but a lower amperage rating. The switch tried to pull too much current, the cellphone power supply fried, and that fried the switch in turn.
It was a deperation move when we were at West Michigan and they announced they were out of DS's, and we only had 1 working port.
We'll be working on something a little more robust and easier to lug around than one of the 12V batteries...
(help)battery chargers Yoel2630 Electrical 19 10-16-2008 08:59 AM
Battery Help ZachKahn Electrical 5 03-06-2008 06:55 PM
backup battery charger circuit help babylyn90 Electrical 4 02-06-2008 06:11 PM
Need help with build a custom circuit for the backup battery midway78224 Electrical 7 01-09-2008 08:17 PM
Help!!! Battery question trollin1st General Forum 7 02-12-2003 08:48 AM
