FRC #2129 Robot with WiiMote
Too bad that you cant use that during a competition
so you have a laptop as proxy ![]() |
Re: FRC #2129 Robot with WiiMote
That's pretty cool. My only question right now is whether or not it will respond to "in between" positions of the Wiimote? Can you make it curve instead of going straight and rotating in place?
It does respond to the in between positions very well, it's analog control.
The WiiMote has a 3-axis accelerometer, not a gyro. It's reading acceleration relative to gravity, which means it will never read 1 g on both the x and y axis. For the video, I decreased the sensitivity so it was obvious that the robot was responding directly to the wiimote, but usually I have about 30 degrees be full power (instead on 90), and on that setting it can easily go forward and turn at the same time. |
Here's two other robots driven with WiiMotes.
http://www.chiefdelphi.com/forums/sh...ad.php?t=62153 http://www.chiefdelphi.com/forums/sh...ad.php?t=75158 |
| MN Splash Dec 6, Teams 1816/2129/2220 | Matt382 | Off-Season Events | 4 | 08-12-2008 17:51 |
| help with Operator Interface and FRC robot Controller | RoarRoar | Control System | 16 | 22-04-2008 09:51 |
| Vex Motor Help with FRC Robot | professorX | Motors | 2 | 13-03-2008 15:19 |
| [VIDEO] Wiimote Driven FRC Bot | Greg Marra | General Forum | 7 | 22-01-2008 07:56 |
| paper: Control an FRC bot with a Wiimote | Greg Marra | Extra Discussion | 8 | 21-01-2008 12:41 |
