Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 26-05-2009, 00:30
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Running DC Motors in Series
I recently finished building a three-wheeled robot using several left over parts from build season. It has two large driven wheels and a caster in the back. Each driven wheel is powered by two CIM motors, each going through a Dewalt gearboxes, and then both linked through sprocket and chain to the wheel output shaft.
In order to control the 4 CIMs, I did not have any spare 12V Victor 884's lying around, but I did have two 24V Victor 885's. The CIM motors from each side are wired in series off of the Victor 885. This setup has worked fairly well, and I haven't had any major issues with it, but I am wondering if there are any disadvantages to running them in series as opposed to each motor having its own motor controller, such as a loss in total power output.
In a standard DC motor, the brushes are always in contact with either 1 or 2 sets of windings. So, in the case of each motor powering one of its windings, the resistance is equal, and each motor should be getting 12V. The same is true if each motor is powering two of their windings. However, if one motor is powering one winding and the other is powering two windings, one motor will get 16V and the other will get 8V. With this setup, would the voltage provided to each motor actually change in this way, and could it be at all damaging to the motor or speed controller?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Running the Motors Backward in WindRiver & cRIO Freezes kyungjin C/C++ 15 08-02-2009 14:24
Running motors together to get more torque vivek16 Motors 14 12-04-2007 16:47
Motors Running Fwd/Rev Paul Programming 3 05-02-2004 17:17
auton mode running motors incorrectly BK36 Programming 2 12-03-2003 02:43
