Gears for CIM
I am in charge of designing a swerve drive for my team. I am having touble finding a spur gear that has the bore size to direct connect to the CIM's.
What i need it for is a CIM with a spur gear direct connect that goes to a .5" axle with another gear on it. I would like about a 6:1 gear ratio but if larger can be found that would be aswome. Note: the larger gear has to be smaller in diameter than a standard FIRST wheel. So if anybody has a place to buy gears for a cim that would rock. |
Re: Gears for CIM
here is a gear that will fit a CIM shaft, you should be able to find some gears that will mate with it at the same web site.
http://store.andymark.biz/am-0034.html not sure if you'll find a 6:1 ratio though...that usually takes two stages of reduction to achieve |
Re: Gears for CIM
The Toughbox has an optional output ratio of 5.95:1 with the 40 tooth output gear and the 24 tooth cluster gear. And what do you know, the output is a .5" shaft. AndyMark must have already thought of this application.
Re: Gears for CIM
Thanks for the quick answers
Re: Gears for CIM
I know this doesn't directly apply to your question, but when your designing the crab drive leave like .003" inbetween gears. If you plan for them to mesh perfectly, youll find they grind a bit and dont spin that well.
Re: Gears for CIM
Matt the bore for the cim gear is 8mm with a 2mm key way.
Re: Gears for CIM
That distance, or looseness between gear teeth is called backlash. http://www.engineersedge.com/gears/gear_backlash.htm ALL gears require some backlash to allow optimal function. Too much causes other problems. Normally, if you buy a set of small feeler gages you can set your backlash consistently. You always want some. |
Re: Gears for CIM
(By the way, the 84 tooth gear they carry has a 1/2 inch stock bore, so all you'll need to do is broach a keyway into it. It also weighs 2 pounds, so be careful )Mike C. |
Re: Gears for CIM
It's not a terribly significant difference, but AndyMark also sells 12 tooth CIM gears: http://andymark.biz/am-0018.html
#10
Re: Gears for CIM
Re: Gears for CIM
If you want to modify a gear yourself or have a shop do it for you, then any stock gear with a 5/16" bore will work.
5/16" bore will work with an 8mm reamer. Ream the gear with an 8mm reamer and broach with a 2mm keyway broach. Add a set screw over the keyway if you want or use the retaining ring as used by AndyMark. |
#12
Re: Gears for CIM
Just to add to this, a Letter O size drill or reamer measures 0.316", and that will work just fine too.
| your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors | waialua359 | Motors | 11 | 14-12-2007 04:29 |
| Gears for CIMs | Brawler006 | Motors | 5 | 18-01-2004 09:46 |
| Replacement for Bevel Gears? | Greg | Technical Discussion | 3 | 30-03-2003 19:56 |
| Spur Gears for Bosch and FP | archiver | 2001 | 11 | 24-06-2002 03:17 |
| Gears for Chipuahs!!! | dense | Motors | 2 | 16-01-2002 20:41 |
