Go to Post week 7: check to see if the pets are still alive, ask significant others to take us back, do 6 weeks worth of make-up homework, and ask my boss for another extension. - Tim Baird [more]
Unread 10-06-2009, 21:01
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
IO
I am trying to build an ROV with an old mainboard running puppy linux as a OS. I want to use the Parallel port and game port for I/O I am currently programing in Java and I am having trouble finding a good way to read specific lines and pulsing specific lines. Does anyone know a good way or do I need to program in C/C++?
Unread 11-06-2009, 03:09
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: IO
Try this setup of paraport libraries. Pretty simple, runs on Liunx and Windows.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 11-06-2009, 09:20
FRC #1178 (DURT)
Re: IO
That looks like it will work. I saw it earlier, but didn't look much. Thanks. Now I just need a way to work with the joystick. I can find pleanty of drivers that will let me read from the port, but I haven't come across anything that will let me send signals yet.
Unread 11-06-2009, 11:00
Re: IO
Write to the 15 pin game port for the joystick? Even in the days of MS-DOS bit banging that was a pain. I'll Google around for MIDI interfaces to see whats out there. You may end up with a C/C++ wrapper for the MIDI port tweeks then making JNI calls for the joystick.
Can you use a serial stream that would come from a MIDI, or are you really looking for the bits to do IO that way?
Unread 11-06-2009, 17:24
FRC #1178 (DURT)
Re: IO
I know with ASM it is not difficult. However, learning ASM is a real pain. There are no nice peak/poke functions anymore. I was hoping I could use the port as a kind of analog send or at least a 5V source for some sensors. However, if it is not possible I can use outboard power. I just thought it would help.
Unread 12-06-2009, 15:13
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
Rookie Year: 2007
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: IO
I did manage to find a joystick library for C a little while ago called libjsw. If you can't find anything else, you could use a C wrapper for this library. Basically, it uses structures for each joystick, pretty much just like the objects in java, so if you can find someone who's good enough with C to break it down, you could rewrite it in java without TOO much complication.
And I like your premise. I've got 5 old (and I mean OLD) laptops sitting around that I've been thinking about repurposing in just this way. If Puppy Linux proves to be too slow (can't imagine it would be that bad), and you need something more time-critical, might I suggest MINIX? It's one of the ORIGINAL Unix operating branches, and has been designed to be tiny. Just food for thought.
If you're not adverse to learning C, this project would probably be quite a bit easier for you. The libjsw library is written in C natively, and there are two functions in <asm/io.h> called inb() and outb() which can access any port on the computer using the hex address. The parallel port is generally 0x378 and 0x379 for write and read, respectively, I believe. There's a good tutorial for C control of the parallel port here. I have managed to run a small motor from a transistor amplifier directly from the parallel port using this method.
Good luck, sounds like fun! And let us know what you learn along the way, I'm going to see if I can convince our team to let me run our summer swerve drive project on Linux.
Unread 13-06-2009, 22:35
FRC #1178 (DURT)
Re: IO
I am not adverse to learning C. I know a little bit, and know several languages based on C, so syntax is basically what I need to learn. I didn't want to use C, though, because I am a better Java programer. Also, I wanted the end program to be as platform independent as possible. The more I think about it, I think I will just use external power.
I used a flash drive to store and run the OS. That way, it can be banged around and moved without having to worry about moving disks. I think Puppy should be fine. It doesn't have a high overhead and I know it will run Java.
