Go to Post Sweeeetttt.....Thats all that needs to be said. :D - george56 [more]
Unread 15-06-2009, 07:15
ramymallouh ramymallouh is offline
ramymallouh is an unknown quantity at this point
RED COLOR DETECTION
hello everyone.....
i am in senior year mechatronics engineering.. my project is Active Traffic And Vehicle warning system..i am kinda new to labview so i'll get straight to the point ..i am now working on 2 USB camera system in the front and back of the vehicle connected to a laptop as a monitoring system...anyway...i want the 2 camera's to detect red color and display a message or a boolean LED or anything indicating there is a red color...i could acquire an image only by using a vi that i found online....but color detection is way better,.....i know i am asking much...but seriously i tried alot and still not able to do it....i am using labview 8.0 and 2 USB camera's that i found in my house that no one uses....and they are both working fine....so if anyone has this kind of program and a bit of explanation about it....i'll be very thankfull........i appretiate ur concern guys
Unread 15-06-2009, 18:58
DonRotolo's Avatar
Back to humble
FRC #0832
Re: RED COLOR DETECTION
Unfortunately I cannot help you (I am not a programmer), but this (red color detection) is a task that was used by many teams in the 2009 FRC game. There is somewhere a VI that does this for you, and so long as you adjust the settings it seems quite reliable.
I am hoping that someone knows where the color tracking VI can be had.
Unread 15-06-2009, 20:06
If you have access to the NI Vision Analysis package, then you can use either the FRC example for color tracking, or you can rebuild it from the color threshold VI. The color threshold takes in an upper and lower color used for thresholding. The results of the threshold will be a mask where the pixels are either ones or zeroes. One if the input pixel was between upper and lower in the color space, and zero otherwise. The next step is to call the particle analysis report VI to describe the blobs in the mask. It can give bounds, area, etc.
Greg McKaskle
Unread 28-06-2009, 09:36
thatnk for the replys guys...i really appretiate ur concern.....but i couldnt even initiate the threshold.vi...it's not working i guess some of the libraries are not workin....and i dont know what to be put where so i can acquire image and analize it.....any other suggestions.....plz...it's urgent....my final presentation is next friday.....i am in deeep $@#$@#$@#$@#......
Unread 28-06-2009, 18:33
If a LV VI has a broken arrow, the button is not grayed out. You can still push it and it will list the errors and hopefully help you fix the issues. I don't know what you've installed or tried. Taking a guess, I suspect that you either don't have vision installed at all, or you haven't activated it. Other issues could be that the camera and computer aren't on compatible networks. You'll get much better help if you describe the errors you are seeing instead of describing how much of a hurry you are in.
Greg McKaskle
Camera detection Jill Technical Discussion 10 14-12-2008 00:29
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 07-03-2008 20:09
Ganged Interrupt Edge Detection cprogrammer Programming 8 01-02-2008 10:52
rangefinding/object detection sciguy125 Electrical 14 13-01-2008 20:36
Collision Detection in Inventor? jlewellen Inventor 2 06-01-2005 21:29
