Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 16-06-2009, 15:09
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
Team 1927's swerve module
if u would like a more detailed drawing i would be happy to provide
This is team 1927's Swerve Module from 2009
The top sprocket is the drive sprocket, and runs all the way through the module. The second sprocket is the steering sprocket and is connected directly to the module.
The module is hooked to the bot by a bearing with a flange witch sits under the steering sprocket (further details are available if needed or wanted)
There were four of these modules on our 2009 robot. The left and right side were individually powered, with 2.5" cim motors running through dewalt transmissions, and the front and back were individually steered. This setup allowed us to have 4 different drive modes: 1. TANK- no steering/ left and right individually powered 2. ACKERMAN- front is steered / left and right individually powered 3. DENALI- front and back individually steered with left and right individually powered 4. CRAB- front and back steered together and left and right powered together
PLEASE leave comments
Unread 16-06-2009, 15:30
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Team 1927's swerve module
Thanks for sharing!
How were you planning on supporting these modules? It looks like you are using 6 inch wheels. Just know that if you plan on using non-rover wheels in the future, you may want to consider supporting the modules from the top and bottom in order to protect against the significant lateral forces the wheel will experience.
Unread 16-06-2009, 16:35
AKA: Chad Krivanec
this was specifically made for this years bot next years will be made using 3" wheels and will be drastically reduced in size
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
