Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 06-21-2009, 07:59 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
PPC bool bitfield
I was working on a library to make some tasks easier on the cRIO, and the library contained a bitfield that looks like this:
Code:
union ORArgs
	unsigned char Value;
	struct b
		bool b0 : 1,
		b1 : 1,
		b2 : 1,
		b3 : 1,
		b4 : 1,
		b5 : 1,
		b6 : 1,
		b7 : 1;
	} Bits;
later, I read that bools are 4 bytes on a PPC system, which we have in the crio, and was wondering if the four bytes would cause undesired effects, like set b0,b1,b2, and b3 to true if b1 is set to true, but after thinking about it for a while, I thought that the first bit of bool b0 would equal the first bit of char Value, and the rest of the bits would be "discarded". unfortunately, I won't have access to the cRIO for another week. Is my first thought or second thought the true one?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 06-21-2009, 09:13 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: PPC bool bitfield
I don't think either is correct.
The ": 1" part of the definition specifies how many bits wide to make the element. If the compiler does what it is hinted to do, the eight booleans will take up exactly one byte. That will map precisely onto the one-byte char also defined in the union.
Unread 06-21-2009, 11:59 PM
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
Rookie Year: 2007
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Since you're specifying the type "bool", I believe the first four make up one bool variable, and the next 4 make up a second bool variable. If you made it a 10-bit bitfield, you'd end up with bool variables and 2 unused bits. At least, that's my understanding. From what I've read on bitfields, that code should be fine. The variable type declarations are really more just the computer's version of bureaucracy, it tells it how to write the memory addresses.
PPC 970FX Beats P4 and AMD64 Joe Matt Chit-Chat 4 02-14-2004 02:52 PM
bool Variables, Autonomous Mode lasindi Programming 6 01-22-2004 10:26 PM
