Go to Post You do use CAD to prototype, Cardboard Aided Design. - Peter Matteson [more]
Unread 28-06-2009, 09:46
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Air valve
One more part I need to find for building a submarine. I need 2 valves to control air flow. One to let air in from a pressurized tank and one to let air out so water can flow in. People keep mentioning sprinkler valves, but I can't find any that will work for air at the local Home depot. We disected them. They have a bladder that is controlled by a solenoid. As the bladder fills, it cuts off water flow. It is very slow and will leak air. Is there something elsewhere that will work that I missed? Maybe an input valve off an old washing machine?
Vacuum Valve Andrew Blair Pneumatics 14 12-03-2007 19:49
Need Valve DPPT1717 Pneumatics 1 13-01-2007 18:49
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Valve Kevin A Off-Season Events 0 19-09-2003 18:58
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
