Go to Post just want a picutre of my "CD idols" - Ryan Albright [more]
Unread 02-07-2009, 13:26
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Lightbulb New TipJar Video: Everything So Far - A Guided Tour of Our Team's LabVIEW FRC Code
Hi Everyone,
I've posted a new TipJar video, giving a summary of the TipJar Videos so far, as a tour of Team 843's FRC code.
http://www.lvmastery.com/TipJar2009-07-02
The purpose of this video is not to teach new concepts, but to relate back to ones taught in previous Tip Jars.
I discuss:
* The concept of robustness: good code can be easily modified, debugged, scaled to work in different situations.
* The Block Diagram, Begin VI, TeleOp VI, Lifter VI, Steering VI, Debugging VI, and Autonomous Independent.
* The uses of the “Command Signal”: initializing it, writing to it, and reading from it.
* The use of “Boolean trigger” to have actions take press on joystick button presses only when pressed or released.
* A consistent and robust approach for programming a robot function VI using a "shifter".
* How to create and use “Re-entrant VIs” to modularize and reuse code for identical robot subsystems in parallel.
* How to use the command signal architecture to create a simple autonomous VI which uses the full functionality of your robot code.
All the best,
Ben
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
New TipJar Video: LabVIEW for C++ Programmers. LVMastery Programming 1 06-05-2009 15:41
New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway LVMastery NI LabVIEW 3 28-01-2009 07:06
LabVIEW Video Tutorial - Debugging Your FRC Code LVMastery NI LabVIEW 0 26-01-2009 09:28
New LabVIEW TipJar Tutorial Video: Scalability, Modularity and Style. LVMastery NI LabVIEW 0 18-01-2009 14:56
New TipJar Training Video - Making Friends with the FRC Advanced Robot Framework LVMastery Programming 0 05-01-2009 14:54
