Go to Post Weight down low is a good thing. Weight up high is not. - s_forbes [more]
Unread 15-07-2009, 14:40
854 bears 854 bears is offline
None #0854
854 bears will become famous soon enough854 bears will become famous soon enough
Help: Bevel Gear Mounted On CIM Shaft?
I am doing a little off season project and experimenting with different ways to mount the drive motors to save space. My current design involves a set of spiral bevel gears, with one mounted directly onto the CIM shaft and the other on an axle supported on both ends. I don't have any experience using or mounting bevel gears, but during my research one source said that these type of gears puts a strong horizontal force on the shafts. All I am wondering is weather or not the CIM will be able to handle this force, or if I need to support the other end of its drive shaft. I don't have many specifics yet, but the gears will most likely be a 3:1 reduction.
PS. these plates will be CNC'd so everything will be precisely aligned, and built strong.
Any suggestions or thoughts will be greatly appreciated.
Thanks,
Team 854
CIM FR801-001 Finding Gear help? 123boo Motors 8 15-01-2009 12:53
CIM motor shaft extender (adapter) Arkorobotics Motors 9 08-02-2006 06:53
CIM motor shaft Coupler Epot86 Motors 13 14-01-2006 22:05
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
