Go to Post It's a twitter post. It's not a hint. - Libby K [more]
Unread 16-07-2009, 18:51
slade2000 slade2000 is offline
slade2000 is an unknown quantity at this point
Gyro Problem
Hi
I am new to all this so any help will be good.
What im doing is im building a camera stabilizer. Ok all works good but there are a small problem with the gyro. What it does it compensates more to the one side than the other. Basicly what i mean by this is. Lets say i move the rig to the left at a 45 deg angle it will keep the camera level but if i move it to the right at a 45 deg angle it wons move the servo completely to where it should be to be level. this result in when i return it to 0 deg it is not level as well.
What can this be?
I use Futabu remote and servo and E-sky ek2-0704 gyro.
Tnx Allot
Unread 16-07-2009, 20:31
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Rookie Year: 2007
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: Gyro Problem
did you try more gain? sounds like its drifting.
Unread 16-07-2009, 21:26
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Re: Gyro Problem
It could be a number of things, such as:
- cross axis sensitivity (either in the gyro itself or because your mounting isn't 100% flat)
- A/D conversion asymmetry.
- Calculation asymmetry due to insufficient fixed point math resolution.
and there are other possibilities. Any more detail on how exactly you're doing it?
An ounce of perception is worth a pound of obscure.
Unread 17-07-2009, 03:26
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Re: Gyro Problem
Could be drift, but it could also be calibration error. In either case, if the rig is left still, it could be observed to slowly drift offcenter of its own accord. If it moves relatively fast and always in one direction, it's a calibration problem. If it's slower and seems to be jittering back and forth, it's more likely to be drift.
Either way, as [Chris Hibner] said, more details are necessary. Posting your code may help as well.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 17-07-2009, 18:02
Re: Gyro Problem
Tnx allot for the reply's. will take a video and post it to show the problem tomorrow.
Gyro problem Ushio Electrical 29 26-08-2009 14:41
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
