Running Multiple Robots Using FMS Light...
We are trying to run multiple robots at once using the FMS light app and 1 router.
Seems pretty straight forward.... The problem is this, we have our wireless N router set to 10.16.25.4 as per the control system manual. The Wireless bridge on the robot is 10.16.25.1 and the CRio 10.16.25.2 the laptop that is running FMS is 10.16.25.6 If we just want to run our 1 robot using those settings FMS detects the DS and the Robot and runs just fine. If we then go to hook up another CRio/DS into the network let just say 10.16.26.x (as if 1626 was also running their bot) FMS will not detect the DS or the CRio. If we change the router settings to match the second bot (10.16.26.x) it will work with that bot but will not detect the 10.16.25.x robot. I have tried 2 different computers and the same problem on both... Has anyone had any similar problems when trying to run multiple bots with FMS Light? Anyone have any ideas as to why it will not run multiple bots at once? I'm hoping its just something simple in the settings i overlooked like some IP not set correctly but ill take any help i can get. Thanks! ![]() |
Re: Running Multiple Robots Using FMS Light...
The FMS light laptop should have the Ip 10.0.0.1. You should also confirm you subnet mask on the PC is 255.0.0.0. Last edited by EHaskins : 24-07-2009 at 23:36. |
I'll give both of these things a try thanks for the help! ![]() |
The correct settings should be, IP:10.0.0.1, Mask:255.0.0.0, Gateway:nothing, DNS servers:nothing Here are instructions for XP. It's the same for Vista or 7, but you go to Network and Sharing center, then click Manage Network Connections, instead of opening Network connections. To get your internet connection back after doing this, you will need to reselect Automatically Configure for both the IP address, and the DNS servers, in the IP or IPv4 configuration page. The router's IP address will have no effect on this, and it may not even be possible to set it to anything less than 255.255.255.0. Last edited by EHaskins : 25-07-2009 at 02:20. |
Thanks for the help |
Change the netmask from 255.255.255.0 to be 255.0.0.0 instead, on both the computer and the router. If I understand the problem properly, that should do it.
| Running Multiple Robots with the old Radios | cbale2000 | Technical Discussion | 4 | 18-10-2007 19:40 |
| Multiple Light Tracking with Distinct Light Boxes in EasyC | hal | Programming | 1 | 19-02-2007 11:56 |
| Multiple Light Tracking with Distinct Light Boxes | MaHaGoN | Programming | 30 | 19-02-2007 10:46 |
| Enabling Multiple Light Tracking Using Kevin's Code | Mitch | Programming | 7 | 05-02-2007 06:17 |
| Using multiple robots at a display? | Adam Richards | Control System | 5 | 02-04-2005 12:44 |
