Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 05-08-2009, 17:01
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
[non-FIRST] External laptop battery pack?
Hello all,
I have a series of ponderings leading to a question or two.
I bought myself an Asus Eee 900A (it is a strange, lesser-known model; apparently it is one Best Buy sold for some time) and its battery life right now is something like 2.5 or 3 hours...with the wifi turned off, screen brightness turned down, and not doing anything to tax the processor. When I am actually using the machine, the battery life drops to like 1.5 hours. That's not long enough for a full class for me. Therefore I am trying to extend it.
My original thought was to take 8 D cells, put them in series, and that would equal 12 volts. Except it might not. And I really don't want to burn up my Eee. I would put a regulator in there, except the highest-capacity 12v regulator I know of has a 1-amp maximum, and my Eee wants 3. I know that's a maximum, but if I don't plan for it, I will definitely reach it.
I'm not sure what to do; any advice anyone could offer would be great.
Thanks,
Jacob
Aren't signatures a bit outdated?
Unread 05-08-2009, 23:14
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Re: [non-FIRST] External laptop battery pack?
I don't know about the little Eee for sure, but at least with my laptops, you can't just replace the original battery. There are too many connections the battery feeds. I assume then that you want to plug the battery into the adapter's plug. It is still not a good idea to run a laptop strait from a battery. The power supplies for laptops create smooth uninterrupted power. There will be no glitches and the voltage will be constant. Plugging in a few batteries will not provide the smooth power nor the constant voltage the laptop needs. The short way to say all this is that you really aren't going to just be able to get something off the shelf and make it work. Just a question. Why not bring the power adapter with you to class and sit near an outlet? Maybe an extension cord?
Unread 05-08-2009, 23:37
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
You could try to find a 12v car adapter for your laptop and plug it into any 12v battery.
Unread 06-08-2009, 07:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Jacob,
I am guessing you wish to avail yourself of the external power connector for this application. D is correct in that the external power supply is regulated. The internal power supply running off the battery is a separate power supply in most cases. It uses a form of boost/buck regulator to keep the various supplies at specification right down to the complete discharge of the battery. You could go to C cells and use 10 or 11 and a three terminal regulator for the 12 volt supply. A high current LM317 will do the job and supply the current but you will need to get rid of some heat on the regulator. Some of the sub C nicads would also do a nice job in this application. The drawback is the weight of the package. There are a variety of boost/buck regulators out there but cost and complexity do factor into the equation. As far as cost vs size/weight, it is almost better all around to find a cheap replacement battery for the internal battery.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 06-08-2009, 09:12
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Apc and a few other companies have made in the past a battery the size of a 14" laptop and it comes with 20 different plugs for laptops. I own one that runs my 15" laptop for about 4.5-5 hours before using the battery on the laptop. There is also a smaller one capable of about 2 hours. I bought mine from Circuit City before they closed for about half price but you should be able to buy them elsewhere for around $100-120.
here's one on ebay
a different style
a different one on tigerdirect.com
Just look around for universal notebook battery
-Mike AA
Unread 07-08-2009, 12:05
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
Team Role: Leadership
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
here's one on ebay
a different style
-Mike AA
Batteryspace.com
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
[FTC]: External Battery Setting ttldomination FIRST Tech Challenge 1 08-02-2009 15:18
Dell Laptop Battery Recall Katie Reynolds Chit-Chat 16 30-08-2006 20:48
Wiring battery pack to motor via switch... Jeremiah Johnson Electrical 5 15-08-2006 18:50
VEX Battery Pack Runtime? TennBikeBerk FIRST Tech Challenge 4 04-08-2005 18:12
Pictures from our FIRST real build day #830 The Rat Pack Don Wright Robot Showcase 8 29-01-2005 09:05
