Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 14-08-2009, 09:33
R.C.'s Avatar
Happy Birthday! R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
pic: FP Gearbox (KOP Gears - 2)
Unread 14-08-2009, 09:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: FP Gearbox (KOP Gears - 2)
This CAD is so good it looks real!
It looks like the pinion on the motor could disengage the first stage reduction under load if the gearbox isn't completely tightened together. Should be easy to fix though. It looks good!
GitHub
Unread 14-08-2009, 10:30
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Great work!
Next step... beat it up, test it, study it, take it apart & put it back together as fast as you can, break it then fix it, install it, run it for 40 hours... then make a list of your lessons learned and go back to the drawing board!
Design is an iterative process...
-John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 14-08-2009, 13:19
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
RC,
Nice! I've got one that looks almost exactly the same, no hex bore bearings on mine though. As you might have figured out from my response to you earlier post, I never measured anything. Mine was built like a wooden boat, build one part and fit the next one to it. Continue 'til done.
Now it's got to go on a robot, and as John says, test, break, rework.
Good job,
Ivan
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Unread 14-08-2009, 13:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
neat! I'm curious why you used hex bore bearings, just turn the ends of the shafts round instead....that's how we made our single stage FP gearbox and it worked fine. easy to make, we had the bearings laying around already
Unread 14-08-2009, 15:19
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We eventually added a 2nd gear parallel to the gear the motor pinion is touching to keep the 2 FP motors from stripping gear teeth off of that gear. We turned the extra hub off of one to fit it in there, it ended up being the difference maker and kept the gearbox running all year w/o any problems.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 14-08-2009, 17:15
I can't tell from the photo, did you remember to make slots or holes for the air to circulate through the motor? I also can't tell if the pinion is making full engagement with the gear. It looks like the engagement is at the very end of the pinion. A thinner side plate (or a recess in the current one) will move that closer to the motor's bearing and make life easier on the motor shaft.
I'm guessing the use of the hex bearings eliminated the need for any lathe work. That's a nice option for teams without access to a lathe.
How are you locating the hex shaft axially?
Unread 14-08-2009, 18:47
R.C.'s Avatar
Brandon, That is a great idea. I think we will end up doing the same.
Funny thing, our whole bot used hex bearings and I think we had over 100 bearings laying around along with over a bajillion bushings. So we have the option of .5 bore, .375 bore, .375 hex bore. So I figured I could be lazy and just use .375 hex all the way.
This was before we added the holes for the air, I relized from another CAD drawing I had that I didn't add the holes for circulation. The pinion fully engages when you tighten the gearbox.
Thanks for the help,
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 20-08-2009, 12:33
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
Where did you purchase the .375 hex bearings?
Unread 20-08-2009, 20:58
R.C.'s Avatar
We didn't exactly "purchase them" they are kinda homemade but it doesn't take any efforts at all to pop out 50+ in about a few hours.
For the 3/8ths bearings, we bought these supplies from mcmaster carr:
-1/2 bore bearings (6383K234)
-1/2 OD - 3/8 ID Bushing (6338K414)
-One 3/8th Hex broach (2875A19)
All we did is place the bushing over the bearing. Then we broached and pressed the bushing in at the same time. They all worked great, We made about 100+ bearings this season. It makes life 10x easier not to have to lathe down the ends, we do have access to one, but we found it easier to interface everything with hex.
-RC
R.C.
Unread 20-08-2009, 22:06
-RC
I'll also vouch for this technique. However we never really needed to "press" the bushings into the bearings, they should kind of slide in snugly.
Unread 14-08-2009, 18:56
R.C.'s Avatar
-John
Thanks John,
I'm going to share this with the team, every team should do exactly what you described. Rookies and Veterans. I have a feeling that I'm going to make a sign with this your quote on there.
-RC
R.C.
pic: FP Gearbox (KOP Gears) R.C. Extra Discussion 2 14-08-2009 00:43
KOP transmission 2006- Pitch of Gears neoshaakti Motors 1 05-02-2008 00:06
KOP gearbox? Andy Brockway Kit & Additional Hardware 52 06-01-2007 18:56
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
