Go to Post You only really ever need 2 things in your tool box: A Hammer to separate things that shouldn't be together, and Duct Tape to put things together that shouldn't be apart. - Dave_222 [more]
Unread 17-08-2009, 19:29
kajeevan kajeevan is offline
FRC #0188 (blizzard)
Team Role: Mechanical
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: Blizzard proto base
Unread 17-08-2009, 19:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Blizzard proto base
Looks nice! I wonder if you could replace the rest of that aluminum with some 12mm and 19mm birch? Worked for us for Lunacy....
Unread 17-08-2009, 20:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
That's a speedy drive train!
I like the use of wood for tthe wheels -- are they 1" wide?
GitHub
Unread 17-08-2009, 21:27
The wheels are 24mm wide. Baltic birch plywood only comes in metric so we take 2 sheets of 12mm spread wood glue on them and sandwich together under a couple of batteries. Then drill a hole and turn them round on a lath. Really easy and is usually done by second day of build.
Unread 17-08-2009, 23:01
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Rookie Year: 2007
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
I have a question I've wondering about for a while.
It seems like lately I've seen a lot of CAD models for drivetrains including wood as material for them, and I was just wondering what the advantages are to this as opposed to using aluminum or some other material?
Is it cost or weight savings that is the main advantage? If someone could shed some light on the topic I'd appreciate it a lot.
Thanks in advance
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 17-08-2009, 23:46
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Thanks in advance
Depends on who you're asking... We realized last year that baltic birch plywood is an amazing material to build robots with because it is very easy to machine and also available locally (meaning we don't have to wait around for materials, which has always killed our build in the past). From our experience the weight has been about the same with our wood frames compared to our other frames, but that wasn't our deciding factor when choosing to use wood.
I like the use of wood wheels in this rendering, that's something that we had been pondering for a while when we were in our drivetrain brainstorming frenzy last year. We never came up with a design that was fast and easy enough to build to make us choose custom wheels over more expensive store bought wheels, though. We are generally pretty lazy...
One other note on the design: I would think that bumper mounting would be easier if the side rails were oriented to make the outside edge of the robot flat (instead of having those flanges). Of course, if the bumper rules follow the trends of past few years then predicting bumper mounting criteria is but the dream of a madman.
Unread 18-08-2009, 09:14
I guess wood vs aluminum wheels or body really depends on team resources and what were used to. Our team has a local metal supermarket so we use aluminum for the body and mill using a Bridgeport digital readout mill. At school our tech department has an open CNC which technically could be used on aluminum and when we tried one summer it worked but took for ever and we decided it was not worth the time or effort. Wooden wheels are super easy to make and we've never thrown a tread or cracked a wheel according to our mentor. We've always made the wheels on a lath but this year since I've learned to CNC I'm going to try and make it on that so to cut our manufacturing time in half.
The flange on the outside is to space the bumper from the bolt heads holding the wheel shafts and Bosch extrusion
Unread 21-08-2009, 00:52
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
I'd be a bit worried about the front. I recall many teams having problems with bumper rules this year. And then there is the possibility of getting hit in a bad spot and bending one of the front forks.
One final question. How much clearance space do you have for the chain?
I'd make the front parts a bit wider or at least put a couple of angle supports in there. A couple of triangles or braces go a long ways in preventing bends.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 21-08-2009, 11:11
I will look into a bit more bracing in the mouth of the base. Also the chain has .25in clearance from the side of the wheel.
pic: Blizzard X - Week 4 Mr. Lim Extra Discussion 9 30-01-2009 14:36
PIC: 1902 Exploding Bacon proto type base Doug Leppard Robot Showcase 11 24-01-2009 12:17
pic: Madtown 1323 Proto 2 R.C. Extra Discussion 12 20-06-2008 20:27
pic: Blizzard VIII Steve W Robot Showcase 28 25-02-2007 00:50
pic: Blizzard Steve W Robot Showcase 22 08-03-2006 08:32
