Brute Forcing Encryption
A couple weeks ago there was a competition by EngineYard in which they challenged people to try to get hash collisions given a list of 1000 words and 5 arbitrary letters. Today I was reading through a thread and saw someone mention cracking the AES encryption on the game manual. So I was curious how often someone mentioned doing that, turns out someone mentions it pretty much every year when the encrypted manuals are released.
Now, I realize that discussion of illegal activities are illegal on this board, but I would assume that a good honest intellectual challenge is always appreciated. Here is the deal, I am going to post a phrase in various hashes (SHA1, MD5, and DES to be specific) I will give you one week to use whatever means you have at your disposal to either tell me the phrase or tell me a phrase that has a collision with the phrase. Now, again I must cover my butt here and restate that the point of this exercise is NOT to teach how to crack encryptions. It is to encourage exploration of various encryption methods and how secure they are as well as writing efficient programs. If you just want to break things don't join in, this is for fun and learning, nothing more. The only prize is bragging rights and knowledge. One last requirement, if you get it you HAVE to describe how you cracked it so that others can learn. No secrets here (except for the actual phrase for the week) So, now that my butt is thoroughly covered and I won't get myself banned(I HOPE) The hashes for this week are: Quote:
[to mods] If this is against the rules I apologize, I felt that it was merely an intellectual challenge from which we may all benefit, please delete and just let me know so I know the bounds of what I can and cannot say. [/mods] Aside specifically to Joe Johnson re http://www.chiefdelphi.com/forums/sh...ad.php?t=41202 I have a feeling that this contest should have the opposite effect, it should let your mother rest easy knowing just how hard it is crack encryption. Last edited by Andrew Schreiber : 21-08-2009 at 23:26. |
Re: Brute Forcing Encryption
What, no AES?
![]() Number of possible phrases: 53^12 = 4.91258904 × 10^20 (12 characters, each one in the set {a-z,A-Z,' '}, 53 elements total) Guess I'll start at the top. AAAAAAAAAAAA? Nope AAAAAAAAAAAB? Nope AAAA... This is gonna be a long night. Last edited by Jared Russell : 21-08-2009 at 23:38. |
To the best of my knowledge, hashes for 12 character long passwords *tend* to be in rainbow tables... If I had enough hard disk space to store some rainbow tables, I'd try it, but that would only work on passwords up to a certain length. I'm sure the 40ish character length of the FIRST passwords makes them cryptographically strong to rainbow tables, unless you have Terabytes upon terabytes of them...
http://en.wikipedia.org/wiki/Rainbow_table For any one curious about what a Rainbow Table is.
There are four separate topics here: - Block ciphers (AES, DES, Blowfish) are what are used to encrypt some data with the use of a key. Then the same key can be used to reverse the process into the original input data. This is the cryptography the manual uses. - Hash functions (SHA1, MD5, RIPEMD-160) are one-way functions that take some input and provide you with a set length output (SHA1 is 160bit, MD5 is 128bit). It is not possible to determine the original input with just the output and the knowledge of what function was used (hence one-way). - Rainbow table is a pre-computed list of the outputs of one-way functions and the input that created them. Using a rainbow table of sufficient size it is possible to easily reverse a hash function but it is easily defeated by padding the input with a know value (salt). - Hash function collisions (what the EngineYard contest was about) is the idea that there will exist more then one input for a possible function output. Since hash functions are the basis for digital signatures (used in SSL certificates for example) it is possible to forge an SSL certificate if you can find a way to pad your input with enough special values to make the hash output the same as an already signed certificate. Since the hash values are the same that same signature would work for both the original and the bad certificate. Now in the original post Andrew provided us with three hash values (DES is not a hash function but I am assuming he means the crypt() function in UNIX that uses a variation on the DES algorithm to create a one-way hash function). A preliminary search of some of the free online rainbow tables yielded no results for me. This would leave us with only the option of brute forcing the algorithm. Now he did indicate that the input was 12 characters which narrows the field somewhat and that the input consists of A-Z, a-z, 0-9, and space. This leaves us with 12 (r) spots for one of 63 (n) values. Using (n+r-1)!/r!(n-1)! we arrive at 21,944,067,106,416 possible values. Now I for one don't have enough time on the University supercomputer to brute force that but if someone has a few graphics cards laying around you could probably build a computer that could crack it in a weeks time. |
2) You used (n+r-1)! / r!(n-1)! to compute the number of possible inputs. This is the formula for the number of COMBINATIONS with repetition. A combination is an un-ordered collection of elements. Order is important for the input string (as "123" hashes to something different from "321" with all of the schemes discussed in this thread); the correct formula to use is therefore the number of PERMUTATIONS with repetition. This is simply n^r as I had done above. n^r = 53^12 = 4.91258904 × 10^20 Quote:
![]() Last edited by Jared Russell : 24-08-2009 at 08:17. |
It has been just over a week, was anyone able to complete the challenge? Did anyone get close?
Abhi wasjust about to send it out to a college computer lab =(
New challenge coming probably tomorrow around 12 (as soon as I think of a 12 letter phrase) The staying up to post at 12 thing was a little late for my non build season sleep schedule.
#10
New phrases
DES - CRKRc/vgbyLyc MD5 - 5bd4c87976f48e6a53919d53e14025e9 SHA1 - 27ceb60ff69ef41a393942a25dcdea0ce5b6c844 This weeks phrase is simpler, 6 letters, no spaces, capital and lower case letters. Also, I encourage participants to post their best Hamming Distance for scoring purposes. Lower scores are better. For anyone curious, PM me if you want to know last week's phrase (if some people are still trying I dont want to ruin it) |
#11
Lostmage333 Has gotten the phrase used to generate these hashes. In the interest of not ruining this week for everyone though the answer won't be revealed yet.
As a hint, the length of this phrase is short enough that rainbow tables become a viable option. |
#12
Pat Fairbanks has also gotten a solution using Python to brute force the answer. It took roughly 14 hours.
| Forcing autonomous to run | Tim Arnold | Programming | 2 | 05-04-2007 20:40 |
| Encryption Cracking Talk. | Joe Johnson | Rules/Strategy | 4 | 08-01-2006 17:17 |
| Forcing a Cable Modem to get a new IP | sanddrag | IT / Communications | 13 | 02-11-2005 06:10 |
| pdf encryption | buss | Programming | 2 | 06-01-2005 23:11 |
| Brute Force... | Andy Grady | Rules/Strategy | 1 | 12-02-2002 22:19 |
