Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 03-09-2009, 21:54
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Encoder problem
We're having some problems coding our traction control. We have traced it back to an issue with the encoders.
Our robot has 7 encoders on it. 1 encoder on each wheel, 1 on our idler wheel, and 1 each on our front and rear steering.
The issue we're having is 4 of the encoders are all changing together when you turn a specific one of the 4.
I'm not sure if this is an issue with the Encoder class, or what
We're coding in C++ using windriver.
Is there like a 4 encoder limitation or something? I ask because it is like the 5th, 6th, and 7th encoders are actually replacing the reference to the 1st encoder, and then the 1,5,6,7 encoders are all referencing to the same place in memory, and are changing with the ports from the 7th encoder. Changing the ports associated with 1, 5, and 6 doesnt increase the count, but changing the 7th set of ports is causing the numbers on all 4 (1,5,6,7) to change.
Problem with quadrature encoder Steve Compton Programming 13 14-03-2009 11:16
[FTC]: Labview Encoder Problem jlester FIRST Tech Challenge 1 08-03-2009 11:27
WPILIB Encoder SetMInRate() Problem vamfun C/C++ 1 28-02-2009 17:58
Encoder Problem DustinB_3 Programming 22 03-01-2007 20:42
Strange Encoder Problem AIBob Electrical 3 20-02-2005 22:20
