Thread Tools |
Rating:
Display Modes |
[FTC]: [FTC]: 2009 Kit Of Parts CAD files
Hey guys,
I was wondering if anyone had the CAD files for Autodesk Inventor and PTC Pro-E for the 2009 Tetrix KOP. I need the newer parts like the: Omni Wheels, Set screw hub, and the chain and sprocket. does anyone know if these files are available yet if so where do you download them? Thanks for the help |
Re: [FTC]: [FTC]: 2009 Kit Of Parts CAD files
They are on all formats SolidWorks ProE Inventor and more on www.3DContentCentral.com. Use the keyword "Tetrix" . Select the file format, year of software (you can go back a few years) and download to your harddrive. Unzip the file.
If you have SolidWorks you can drag/drog a 3DContentCentral part right into the graphics window. To link to the folder where you put all your robot components, from the Design Library, use Add Folder location, browse to your robot component folder on your desktop - this will save you alot of time when creating assemblies. Before you start your assemblies - really think about symmetry, mirror component and component pattern. Build the sub assembies as you would physically assemble them. If you need SolidWorks for FTC, go to www.solidworks.com/SponsoredDesignContest Marie |
Oops I just realized we have the omni wheel from FRC - I have to look for FTC. Will call manufacturer for you on Monday if no one has it. Marie
Thanks Marie! Should we link to these on 1323's library for others who might be looking for the parts? Or should they be uploaded and categorized for faster reference?
http://team1323.com/cad/index.html Last edited by Akash Rastogi : 13-09-2009 at 14:20. |
Re: [FTC]: 2009 Kit Of Parts CAD files
Marie thank you for the recourses, but i already have the 2008 kop i need the new parts in the 2009 kop like the omni wheels, sprockets, set screw hubs, and tube plugs which are not on the PTC list or 3d content centrals list either.
I'm assuming they will have them up in a few days. I'll just have to wait for the update i guess. Thank you though Andrew |
Hi Andrew
I called my colleagure responsible for the Tetrix parts, a great SolidWorks user, who actually makes the new parts - it is always better to get the model from the source. When the model is created in SolidWorks it can be downloaded in any file format from 3DContentCentral. Give me a day or two. I think this might work. Marie |
ok thank you very much Marie this is going to be a great help!!
Andrew |
where you given the part numbers - or is it just one big kit? Marie
#10
#11
Thank you - I will add the part numbers when I get them
Here are the models for the new Tetrix Sprockets. I am working the the others. Should be up shortly. Marie Sprocket X25T: http://www.3dcontentcentral.com/Down...d=171&id=17063 Sprocket X32T: http://www.3dcontentcentral.com/Down...d=171&id=17062 Sprocket X16T: http://www.3dcontentcentral.com/Down...d=171&id=17061 |
#12
Here are the rest that I have:
Omni wheel: http://www.3dcontentcentral.com/part...atalogid=171#1 Omni wheel joining hub: http://www.3dcontentcentral.com/Down...=171&id=17060# Tetrix Axle hub: http://www.3dcontentcentral.com/part...catalogid=171# DC Connector: http://www.3dcontentcentral.com/part...&catalogid=171 Tubing Plug: http://www.3dcontentcentral.com/part...&catalogid=171 When you search use FTC, Tetrix, 2009kop. If I get more I will post here too. If you need something let me know. If you want to make your own web page with 3DContentCentral models embedded so they zoom, pan and rotate, just copy/paste the embed link on your web page. Here is an example of a web page with the models embedded. http://blogs.solidworks.com/teacher/...arts-2009.html Wait a few seconds, all the new Tetrix models are posted on this page and it will take a moment to come up. But the results are really cool. You can move the Omni wheel around. Good luck in the competition. Regards, Marie |
#14
CAD Model for Plastic Wiffle(r) Baseball, 9in circumferernce, 2.86 diameter, 25.5grams (.9ounce). Available in white or yellow configurations.
http://www.3dcontentcentral.com/part...catalogid=171# I believe this ball is made of PVC, the mass is correct - but if you think the slot size should be different, please let me know. I dont have the actual ball. Be certain to check both configurations if you want yellow and white. If you want to create a linear pattern of baseballs, use the sketch line I used in the slot cut as a reference in the assembly. This will save you time. Baseball is available in all CAD file formats. Marie |
| [FTC]: FTC Game Platform for 2009-2010 | Rick TYler | FIRST Tech Challenge | 30 | 27-04-2009 20:17 |
| 2008 FTC Kit of Parts (Pro/ENGINEER format) - Supported by PTC | PTC_FRC | CAD | 0 | 19-01-2009 22:44 |
| [FTC]: Same Parts in 2009-2010 Season? | Rick TYler | FIRST Tech Challenge | 5 | 11-12-2008 21:35 |
| [FTC]: CAD Models of Tetrix parts? | Madison | FIRST Tech Challenge | 2 | 23-11-2008 08:49 |
| [FTC]: Rookie Team Needs Help With Tetrix FTC Kit! | rjustice4 | FIRST Tech Challenge | 8 | 05-10-2008 09:44 |
