Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 20-09-2009, 18:03
abrown128 abrown128 is offline
FRC #1710
abrown128 is an unknown quantity at this point
25 Series Chain
I was wondering if I could get an opinion on 25 series chain and whether it would be strong enough for a swerve drive, rotating the modules and driving the wheels.
Unread 20-09-2009, 18:08
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: 25 Series Chain
The short answer is yes. We've done it, I know 1625 has done it, I think 118 did it and I'm sure there are others.
The long answer is it depends. The Size of the wheels, torque of steering motors, size of sprockets, etc... Chain manufacturers post specs for their chain, and it actually isn't too difficult to check if your within the working range.
Unread 20-09-2009, 18:24
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 25 Series Chain
Strong enough? Yes, plenty.
Easy to work with? Not exactly. Because of the smaller sprocket tooth size, the tension of the chain is critical, much more so than #35. But, manage that properly and it'll be fine. Key word: Properly.
Unread 20-09-2009, 18:27
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: 25 Series Chain
We made a C-base this past year with #25 chain on it. We put it through it's paces and put it in some tough pushing matches and it faired really well, meaning it didn't break.
1648: 2013-2014
5283: 2015
Unread 20-09-2009, 18:34
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: 25 Series Chain
Yes, #25 chain is plenty strong enough, as long as it's tensioned properly, and is not subjected to any twisting forces. Because it's so small, #25 chain is quite sensitive to being twisted, much more than #35 chain.
We used it to steer our swerve modules on our 2007 robot, and it faired pretty well.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 20-09-2009, 22:29
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Re: 25 Series Chain
I just want to add a few things about #25 chain. You can really only buy master links for #25 chain online, most local retailers won't have any smaller than #35. Also, the clips on the master links really like to pop off (it has happened to our robot twice last year, once during build, once during a match, and our chains were properly alligned with little or no twisting forces). Check them frequently to see if they are bent if you can, and if you have to take on off, replace it with a different clip.
Unread 20-09-2009, 23:48
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Re: 25 Series Chain
Interesting. Apart from one time*, I've never had that problem on any of the bots I've helped with. That comes from 3 years of using #25 chain on 971's drivetrains and arms, and mentoring 254 this year (though I haven't heard of them having trouble with that in the past either). I'd say you guys need to make sure that the clip on the master link seats in it's grove before you call it done.
*The only problem I have ever had with that was when the kid who cut the chain to the right length inadvertently pried apart the sides of the link with the chain breaker so that it was too wide for the clip on the masterlink to seat. He didn't know that that could happen and cause a problem, so he didn't worry about it when he cut the chain. I carefully squeezed it back into shape with a wrench, and we never had a problem again.
Unread 21-09-2009, 06:44
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: 25 Series Chain
25 chain should be strong enough for pretty much all applications on a first robot. My team used it on our swerve steering in 2008, and never had a problem.
Unread 21-09-2009, 08:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: 25 Series Chain
We use #25 and custom built adjustable chain tensioners for the obvious reasons and for wheel alignment.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-09-2009, 09:11
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: 25 Series Chain
1771 has used #25 chain as our drive chain for the past two years w/o a failure. Although the floor and wheels made this year a poor example since they limit the stress on the whole drive train.
Former Mentor Team 1771
Former mentor Team 4509
Unread 21-09-2009, 10:08
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: 25 Series Chain
I would recommend using a spring tensioner for it, because this way you're guaranteed to have tight chain. The problem with adjustable chain tensioners with screw adjustments is that they can come loose.
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Inspiration Series: Movies! Eugenia Gabrielov Chit-Chat 15 22-06-2004 15:27
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
