Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 25-09-2009, 12:01
Christine3491 Christine3491 is offline
FTC #3491
Team Role: Coach
Christine3491 is an unknown quantity at this point
[FTC]: Building Low Cost Playing Field
Our team is new to FTC and trying to build the low cost playing field following the diagrams on the FIRST website.
http://www.usfirst.org/roboticsprogr...t.aspx?id=6654
I can't figure out how it's is suppose to be 12' (144").
There are 3 long pipes that are 43.5 inches. The T-connectors from our local hardware store are 2.75" total (with .75" overlap of pipe on each connection), so the additional length is actually 1.25" per T-connector. There are two 1.75" pieces at the ends that fit into 90d connectors. The 90d connectors don't add length to the inside of the playing field.
Here are the numbers.
3 x 43.5 = 130.5
4 x 1.25 = 5
2 x 1.75 = 3.5
The total is 139" which is much shorter than the 1" variance on 144".
Even if we add an extra T-connector to the center panel for the side reinforcement, the total is only 140.25".
How do we create a 12' playing field?
Should we be lengthening the small pieces (two 1.75") to get the correct length?
Are the T-connectors we're using shorter than ones available in the US?
Is it the inside of the playing field that should be 144"?
Thanks.
Unread 26-09-2009, 08:57
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: Building Low Cost Playing Field
The answer to the question is found in the FIRST Hot Shot! Q&A Forum (Post #7): forums.usfirst.org/showthread.php?t=12917
[FTC]: Full Field vs Low-cost Field 595294001 FIRST Tech Challenge 13 04-05-2011 19:10
pic: FTC "Quad Quandary" low-cost field at CT kickoff event KathieK Extra Discussion 5 24-09-2007 16:19
Building your playing field....and how long it takes shotgunking777 General Forum 19 17-01-2005 14:29
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
Building the Playing Field AJ Quick General Forum 15 13-01-2003 19:15
