Go to Post You're not on your own, use your team members. They are the most valuable source of ideas that you have. - fr05ty27355 [more]
Unread 27-09-2009, 18:51
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Rookie Year: 2007
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
MPLAB and 62 char filename limit
Hey. I just did a rewrite of the code for the 2005-2008 robots we have lying around, since we were either missing it or it was partially broken... Anyway after fixing the multitude of syntax errors and linker errors () I got a very interesting linker error. It said something along the lines of "file C:\Users\Team1546\Desktop\Robotics Code\Current\Pre-09 Code Base\v1.3\autonomous.o violates 62 character filename limit". I solved this by simply moving the project directory (v1.3) to the C drive root and it built just fine. I'm wondering if there's any solution for this rather annoying filename limitation or if I just have to live with it. I'm running Vista, if that matters.
Compiling...
Compiling...
Interrupts, limit switches, and IR board Neurovirus Programming 4 15-02-2008 11:56
Unsigned Char issues Ben_R_R Programming 0 30-01-2008 20:25
WPILIB: WriteSerialPortOne(unsigned char) Warning on Compile Chris_Elston Programming 2 24-01-2008 09:44
pic: Long Filename CD47-Bot Extra Discussion 11 06-03-2003 18:31
Dashboard programs and the char variable Ian W. Programming 13 26-06-2002 02:07
