Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Unread 07-10-2009, 22:54
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
NXT Mindstorm Teleop EXamples
Does anyone have any sample teleop programs for the NXT using Mindstorms?
Thanks a bunch
Unread 07-10-2009, 23:26
kmitchell kmitchell is offline
kmitchell is an unknown quantity at this point
Re: NXT Mindstorm Teleop EXamples
Does this help?
http://www.education.rec.ri.cmu.edu/...xt_g/index.htm
Unread 08-10-2009, 10:20
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
The FTC Toolkit for LabVIEW ships with two teleop examples (FTCTeleopServo.vi and FTCTeleopStealth.vi). The teleop template code (FTCTeleopBasic.vi) can drive a robot with no programming required, but it does require your motors to be configured like the robot in the Getting Started Manual.
All of these VIs can be found in the following directory:
C:\Program Files\National Instruments\LabVIEW 2009\examples\FTC Toolkit\
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 10-10-2009, 07:56
FTC #0658
ok thanks i'll give them a try
Unread 10-10-2009, 09:48
Billfred's Avatar
Billfred Billfred is offline
Moved this thread into the FTC forum, for clarity's sake.
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
mindstorm and pong RX7-bernie General Forum 1 01-03-2007 14:54
Mindstorm Instructor RX7-bernie Career 2 25-01-2007 10:07
Lego MindStorm NXT Gamer930 Lego Mindstorm Discussion 1 10-07-2006 09:21
Entrepreneuship award examples Dr. Acula General Forum 12 13-01-2006 19:16
