Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 08-10-2009, 09:17
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
[FTC]: Tetrix Battery Pack Internal Short Circuit
The students were taking their parts and robot chassis out of the storage container yesterday, when one of them called out to me, "Hey our battery pack is smoking!".
We disconnected the battery pack from the robot and took it outside until the "fireworks" were over. Both the black and red wires were cool, except that the black wire had come unsoldered from the tab on the battery. The fuse was not blown. Only the first cell at the negative end of the stack got hot. It appears that the metal tab attached to the end of last battery, to which the black wire is soldered, cut through the heat shrink insulation and the plastic covering of the adjacent battery. The case (-) of the adjacent battery is connected to the terminal (+) of the last battery, so when the tab connected to the case, there was a direct short across the last cell.
(see attached picture)
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
[FTC]: Anyone new to FTC or TETRIX, READ THIS NOW! PhilBot FIRST Tech Challenge 21 04-12-2009 17:34
[FTC]: FVC (Vex) VS. FTC (Tetrix) jbbjjbt FIRST Tech Challenge 79 24-09-2009 12:39
[FTC]: VRC (VEX) AND FTC (Tetrix) jbbjjbt FIRST Tech Challenge 1 21-09-2009 14:59
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
Camera Short Circuit? MustangRobotics Technical Discussion 3 18-01-2006 14:42
