Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 10-10-2009, 12:25 AM
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Pneumatics Code
Hey, thanks to some great help from Jon236, Alan Anderson and Mark McLeod, I think I got some code that *might* work with the pneumatics system...
If someone could take a look over it and maybe give me some pointers, that'd be great! (School is closed until Tuesday...Furlough days. )
Code:
#include "WPILib.h"
#include "1771Constants.h"
#include <iostream>
using namespace std;
namespace Team1771
class Team1771Robot : public SimpleRobot
	RobotDrive driveTrain;
	Joystick leftStick;
	Joystick rightStick;
	Joystick manipulator;
	Compressor compressorControl;
	Solenoid turret;
public:
	Team1771Robot(void):
		driveTrain(LEFT_DRIVE_MOTOR_PORT,
				   RIGHT_DRIVE_MOTOR_PORT),
		leftStick(LEFT_JOYSTICK_PORT),
		rightStick(RIGHT_JOYSTICK_PORT),
		manipulator(MANIPULATOR_JOYSTICK_PORT),
		compressorControl(3,3,COMPRESSOR_PORT,7),
		turret(5)												//THIS *HAS* TO BE CHANGED
//I just made up random number
//TODO: Figure out how to hook it up!!!
		compressorControl.Start();
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		while(IsAutonomous() && !IsDisabled())
	void OperatorControl(void)
		while (IsOperatorControl() && !IsDisabled())
			//FIRE AWAY CAP'N!
			if(manipulator.GetRawButton(1))
				//Seeing if I have enough. Just a rough estimate.
				if(compressorControl.GetPressureSwitchValue() < 100)
					cout << "Not enough power to fire. " << endl;
					cout << compressorControl.GetPressureSwitchValue() << endl;
					Wait(1);
				else //Fire into the crowd! Rawr!
					//Uncomment to see pressure values before firing
					turret.Set(1); //I think this will tell the solenoid(I think its the solenoid?)
					//to switch and let the air fire from the chamber.
					turret.Set(0);//Then that should turn it off?
					//TODO: Figure out if 1 is letting air in, or if 0 is.
					//Uncomment this below for seeing how much pressure we lose from firing.
					Wait(1);
START_ROBOT_CLASS(Team1771Robot);
One of my questions that I already have however, is with the Compressor.Start()
I noticed in the Compressor.h file, there is a function called void SetRelayValue(Relay::Value relayValue). Does the Compressor class automatically call this is needed?
From what I understand, calling compressorControl.Start() will turn on the compressor, and automatically keep the pressure to a certain level.
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 02-06-2007 04:48 PM
problems using gyro/adc code with camera default code tanstaafl Programming 7 01-22-2006 11:09 PM
Pneumatics-Code [and piston output length] reilly Programming 5 02-13-2005 11:42 AM
Pneumatics-Code [and piston output length] reilly Technical Discussion 0 02-10-2005 12:21 PM
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 01-31-2005 10:28 PM
