Go to Post I just think the teams that will be winners will have a higher score then us :) - Kyle [more]
Unread 12-10-2009, 13:45
javalynt344 javalynt344 is offline
FRC #0858
javalynt344 is an unknown quantity at this point
wheel tracking
My team uses a crab drive for driving the robot. All four wheels are on mounts, which are connected to a chain that goes around all four mounts. There is then another motor that turns the chain, in turn, rotating all of the wheels at the same time.
Anyway, I need some help. I have been trying to figure out how I can track the rotation of the wheels. This way, the driver can see which way the wheels are pointing on the dashboard.
I need help finding out how to do this, do I use encoders, gear tooth sensors, mathmatical equations, etc. Any help would be appreciated.
Unread 12-10-2009, 15:36
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Re: wheel tracking
Welcome to the forum Take a look around, there's a lot of info here already.
While it depends on what kind of crab you're building, what you probably want is called an absolute encoder, which you can think of as like a potentiometer, except that it can twist forever, and outputs the angle from the zero position. My personally preferred brand when it comes to encoders is US Digital, but shop around. Connect it near one of your wheels, so that one rotation of the sensor equals one rotation of the wheels.
Alternatively, if you're using a non-coaxial design, i.e. your modules can only turn a certain number of times in one direction before your cables get wound up, you can use a multi-turn potentiometer, which will allow you to sense where in their entire rotational range your modules are.
Good luck,
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 13-10-2009, 12:52
FRC #0858
Re: wheel tracking
Thanks Ryan, great idea, I will look into it!
Change two color tracking vi from tracking pink AND green to orange OR grape balls star_lancer Programming 5 14-02-2009 20:58
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
