Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 13-10-2009, 10:19
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
CAN Design Kit
I was wondering if we would be able to use something like this if FIRST allows us to use CAN. What would be the benefit of using a CAN design kit or is this unnecessary?
Unread 13-10-2009, 12:51
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: CAN Design Kit
I believe this kit is essentially just a CAN-enabled Jaguar with a motor.
Note: I would hold off on purchasing something like this now; teams are currently beta testing the brand new CAN-enabled "Black Jaguar" that will improve several aspects of the Jaguar.
Here's a FIRST Forums thread (and image) about the new CAN-enabled Jaguar:
http://forums.usfirst.org/showthread.php?t=12983
Unread 13-10-2009, 19:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: CAN Design Kit
The advice to hold off on buying anything is good.
You asked what benefits this kit can offer. The short answer is that if you need to develop something that uses the CAN Bus interface, this will help you do it more easily. Think of it as a small toolbox for CAN control of Jaguars. BUT, it is unlikely that FRC teams will be asked to develop the CAN interface; instead it is more likely that software tools (such as a VM for LabView) will be provided, and teams will merely have to parameterize (fill in the blanks) it to use CAN.
This would be an excellent question to ask Luminary Micro. Their sales support team answers questions like this every day, and if you identify yourself and ask a question, they'll provide an answer. (That's how it's done in the business world).
Unread 13-10-2009, 21:17
dmcguire3006 dmcguire3006 is offline
FRC #3006 (West High FIRST Robotics)
Team Role: Teacher
dmcguire3006 is on a distinguished road
Re: CAN Design Kit
We got one of these just to familiarize ourselves with CAN. This particular device simply implements a CAN interface and allows the user to select (and set) the motor ID # and then control the Jag over the RJ11 connector via a simple LeftRightUpDownSelect menu and the OLED display. After learning all we could from this device, we converted into a handheld motor tester inside a RadioShack project box.
Unread 04-12-2009, 18:32
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: CAN Design Kit
To interface with the CAN bus is it necessary to buy the NI 9852 CAN bus interface module?
This has a price of ~$1100, and so would not be legal on a USFIRST robot under previous rules, where the limit on any single component was $400.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 04-12-2009, 18:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: CAN Design Kit
This has a price of ~$1100, and so would not be legal on a USFIRST robot.
I can think of a way it would be legal. Several, actually.
1) KOP item. KOP items and spares for them are not counted in cost accounting (until you get more than KOP quantity).
2) Discounted price (<$400) available to ALL FRC teams.
3) Change in the cost accounting rules to allow it.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 04-12-2009, 19:19
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: CAN Design Kit
Option 4 would be not to use the NI CAN interface, but use another method. See http://forums.usfirst.org/showthread.php?t=13440
Unread 04-12-2009, 21:53
None #0612
Re: CAN Design Kit
This RS-232 to CAN interface would be much more economical:
http://www.factorycomm.com/gc-can-rs232.html
Unread 04-12-2009, 23:23
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: CAN Design Kit
Originally Posted by Joe Ross View Post
Option 4 would be not to use it. See http://forums.usfirst.org/showthread.php?t=13440
Thanks Joe and 330 for your great work with the beta testing...
I have found that you should listen to beta testing teams and read the forums especially the FIRST beta testing one.
http://forums.usfirst.org/forumdisplay.php?f=1260
CAN will provide great possibilities but it appears that it won't happen this year.
We can still hope.
http://forums.usfirst.org/showthread.php?t=13313
Thanks all beta teams for all of your help!
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 07-12-2009, 12:58
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: CAN Design Kit
What is going on with Tucan? The ethernet to CAN device I saw from cross the road electronics....
They demoed some impressive technology at IRI that would make talking to your CAN-enabled Jaguars a snap.
Also, I think all Jaguars are CAN enabled, even the kits items from last year. Can anyone verify this?
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 08-12-2009, 22:24
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: CAN Design Kit
Anthony, Jaguars have always been CAN enabled even last year. Teams were just not allowed to use the CAN interface.
Attached is a picture of the 2CAN. It will be released shortly. The price will also be announced shortly but I will say it has more features, more power and is cheaper than the Chicklet(129.99). The pricing is for FIRST teams only, as this device has many applications outside of FIRST. The web site has not been updated to show any information about the 2CAN. It will be updated soon and will have links to firmware updates, user manual and example drivers for the cRIO and possibly a link with live video stream that users may control motors over the internet with. The picture does not show dimensions. They are 3" x 2.5". this does not include the mounting tabs which make the overall 3.25" instead of 2.5". It is smaller than Jaguar but bigger than a Victor.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 09-12-2009, 00:40
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: CAN Design Kit
Will it be legal for the season?
Unread 09-12-2009, 03:15
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Re: CAN Design Kit
I'm guessing that we won't know for sure until the rules come out... I'm sure I've heard that phrase around here somewhere on the forums before by a certain individual Anyways, this looks like a very nice device.
Even if it isn't legal, it opens up a huge number of options. All you need to drive a robot would be the wireless bridge and some custom software on a networked computer driving it. Depending on what data is accessible over the CAN bus, you could even implement some closed loop control and use sensors. A lot less expensive than a second CRIO, and it would work for probably 90% of the robots out there without any loss in functionality.
Unread 09-12-2009, 03:38
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: CAN Design Kit
Actually one intended use for the 2CAN is to be the backbone for a modular based control system. Basically it opens up ethernet to the world of CAN and vice versa. So your point about any ethernet device being able to drive a robot is absolutely correct.
Furthermore the 2CAN was not intended to be a replacement for the CRIO. However, with some small changes to the enable/disable protocol, it could free up the FPGA for teams to use (I suspect the FPGA is used for this purpose and this is why teams do not have access to it).
  #15   Spotlight this post!
Unread 09-12-2009, 09:41
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: CAN Design Kit
Thats the part I'm really excited about. I'll bet we'll see a lot of practice bots that are an off the shelf wifi router/bridge/whatever and a 2CAN. Can't beat that!
**FIRST EMAIL**/2009 Kit of Parts Now Available in Autodesk Inventor and Design Comp. Mark McLeod FIRST E-Mail Blast Archive 1 06-01-2009 08:16
can we use 06 kit of parts? Tri_Lam General Forum 6 16-01-2007 21:25
***FVC Programming Kit/Bundle Kit Upgrade*** KathieK FIRST Tech Challenge 0 04-12-2006 19:57
pic: Kit Transmission Upgrade kit Andy Baker Extra Discussion 17 29-01-2006 01:27
can we use motors from last year's kit? Amittt Motors 5 22-01-2006 22:27
