Go to Post Nothing like GLR for your inaugural stint as a coach, lemme tell ya. - Kevin Sevcik [more]
Unread 16-10-2009, 00:05
kevinbrice kevinbrice is offline
Kevin Brice
FRC #2102 (Team Paradox)
Rookie Year: 2007
kevinbrice can only hope to improve
Team 2102 Problem With Control Interface
Hello,
We use our 2009 robot often for demos or sponsor presentation. Within a presentation, out of nowhere we completely lost control. Our drive is 4 wheel drive 4 wheel steering. We have a steering centering portion of our code, as well as a recognizable autonomous mode. Heres the current symptoms which started suddenly without any changes to the robot:
No driving control whatsoever through joysticks or gamepad, when autonomous switch is toggled, the robot does start auto mode. When set to teleop, it drives forward full speed, no other motors move except steering centering. Disable switch stops robot. Drivers station is fully updated. We checked wiring all seems correct. Cannot figure out problem! Please help!
A programing mentor thinks it might be a timer on the first side of the crio programing which ran out, any similar problems? Any suggestions?
Thanks
Kevin Brice
Team Paradox 2102
sdarobotics.org
Problem Getting Victors to run with the new control system Boommaster713 Programming 11 15-02-2010 15:29
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
2008 Team Paradox 2102 Robot BordomBeThyName General Forum 11 09-03-2008 21:27
Operator interface/Driver Control board sgsdragons Robot Showcase 4 07-03-2005 08:58
Operator Interface Control Panel wmurphy Control System 4 30-01-2005 23:57
