[FTC]: FTC Cad Parts
Is there any way that I can download the entire FTC KoP from www.3dcontentcentral.com ? All of the parts there are perfect but it's a pain to download each part individually.
Re: [FTC]: FTC Cad Parts
I found this link somewhere else, and the only problem is that I am using solidworks 2008-2009. After some searching around on the web, I found some forums that were discussing importing pro/E parts into Solidworks, and while some of them say that it is possible, every time I try to, nothing happens.
I know that it's possible because I know that my team did, but I'm not exactly sure how we did it. Sorry I can't be of more help.
i just downloaded each of the parts for all the programs i have it may take a while but it goes fairly quickly
Yeah that's what I'll end up doing, I just wanted to check for a faster way before doing it like that. Marie, do you have a solution?
Let me see what I can do. You want the FTC parts in one location in SolidWorks format - correct?
Marie |
Yes, available as one download
for Pro-E i know you can download everything at once
#10
from 3dContentCentral into your assembly. View the video on youtube, http://www.youtube.com/watch?v=Oy_MZ... FAF31&index=2 Although these movies were created for car design, the technique is the same. Select the First Robotics or VEX Robotics category under User Category for My Favorites. Create a common directory for all 3DContentCentral parts when you download. Remember to customize your Design Library to include this folder of parts - it will really make life easier. You can drag them into additional assemblies. Tip: Think about subassemblies first - how would you assembly this physically? What parts move and what are fixed. Use reference axis for rotation to mate to. Marie |
| [FTC]: [FTC]: 2009 Kit Of Parts CAD files | Andrew Remmers | FIRST Tech Challenge | 15 | 16-09-2009 11:12 |
| [FTC]: FTC parts website? | ttldomination | FIRST Tech Challenge | 3 | 29-01-2009 00:15 |
| [FTC]: CAD Models of Tetrix parts? | Madison | FIRST Tech Challenge | 2 | 23-11-2008 08:49 |
| [FTC]: FTC Tetrix Extra Parts | Team 288 | FIRST Tech Challenge | 2 | 22-10-2008 18:30 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
