Go to Post You can take my blocker... but you can never take my cheesecake! - Andrew Schreiber [more]
Unread 01-11-2009, 15:29
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
pic: 955 T-Shirt Bot @ Halftime
Unread 01-11-2009, 15:30
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Re: pic: 955 T-Shirt Bot @ Halftime
That thing looks sick! The middle tube is the firing one, yes?
I'll bet it scared the @#$% out of the other football team!
Unread 01-11-2009, 20:49
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
PingPongPerson will become famous soon enough
I heard that the robot didn't turn that well. I still wish I had gone to the game.
Unread 02-11-2009, 01:34
Fe_Will's Avatar
AKA: Will
Correct, the outer tubes are tanks and the center tube is the barrel. We can fire one tank or the other, or both at the same time. The biggest issue was the amount of energy required to operate the robot. We simply didn't have enough batteries.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 02-11-2009, 10:01
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
What was drawing so much energy?
Unread 02-11-2009, 10:41
Fe_Will's Avatar
AKA: Will
Inside there are five kit compressors and four CIMs driving AM 6" mecanums through Banebots 12:1 planetary transmitions. All of the compressors are powered by one battery and the drive, elevation, and controller are powered by the other.
The issue is trying to run the compressors over an extended amount of time. We can fire about three shots at max pressure before the battery is drained. The other issue we didn't plan for was firing when our team scored, it is unpredictable at best and holding pressure for long periods of time means the compressors tend to be "topping off" constantly. Either getting a battery better suited to the job or having a setup where we can keep it plugged in most of the time are the options we are considering.
The other slight issue is that fact that the robot weighs about 275 lbs. It is taxing our drive as is and we are considering changing our gear ratio to 16:1. Adding excessive weight at this point wouldn't help us be mobile
Unread 02-11-2009, 11:14
Data Nerd
FRC #0079
Rookie Year: 2000
Hmm, 5 compressors, I suppose that would do it. Are you cooling your compressors at all? From my experience in 2008 (my only experience with any sort of pneumatic system) we found that the compressor works much better when kept cool.
Also, and this is something that the electronic people will have to help you with, (by which I mean NOT me, I'm software) what about having 2 or 3 batteries on there? Yes it would increase weight but it would mean you have more energy stored.
And yes, at that weight I would think that the 16:1 would be a great idea, I'd be interested in knowing how hot your CIMs are getting moving that much weight.
One more question, how do the mecanums handle the track? What type of track is it?
Unread 02-11-2009, 20:25
Fe_Will's Avatar
AKA: Will
We have 6 fans (3 pulling in air in the front and 3 pushing air out the rear) cooling the inside. There is a good flow going through the unit. We already have 2 batteries in the robot. I would rather find some other type of battery (non-kit) to run the entire system then keep adding more batteries.
The CIM motors do a great job in forward and reverse. Its the power loss when driving sideways that is gimping our movement, we believe. The only issue with the track is the red color so far. Our track is relatively new (about 5 years) and when it is damp the red gets on everything.
Unread 02-11-2009, 20:28
Data Nerd
FRC #0079
Rookie Year: 2000
Well, then I am out of bright ideas
Unread 02-11-2009, 20:34
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
No fair, our coaches are too paranoid to allow a robot on the track because of the wheels. Nice design! Our T-Shirt launcher was just made and isn't tested; it is backpack mounted.
Go REX!!!
Unread 03-11-2009, 10:38
Fe_Will's Avatar
AKA: Will
The trick is to get your administration excited about it. You could only imagine the look on our athletic director's face when the principal told him at the last minute that he was providing the shirts at the football team's expense.
Unread 03-11-2009, 10:49
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
what are you using as your valve? I would be very curious to see a closeup of it and/or parts numbers.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
FIRSTcast: Season 4 Episode 7 - Halftime Jeff Rodriguez General Forum 0 27-01-2009 12:55
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
Team 955 Karma Website Design/Showcase 7 25-02-2005 01:22
Team 955 Animation Storyboard Li Jianliang 3D Animation and Competition 0 13-02-2005 16:01
Congrats to 254, 1425, 753, and 955 Nate Edwards Thanks and/or Congrats 2 21-03-2004 18:13
