Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
Unread 06-11-2009, 00:06
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Build Your Own CNC Machine - book
http://thenxtstep.blogspot.com/2009/...t-of-mine.html
Found this recently, looks really interesting. Instructions on how to build your own CNC machine; will be released in November along with a website. The CNC can be built for ~$800. That's a lot cheaper than buying one. However, some will argue that depending on your team, it's probably not worth it. The big dogs have enough money and resources to buy their own CNC machines, but everyone else could/has been getting along fine without them. The big deal is that they can machine parts, specifically complex ones, quickly and accurately. So that's something to be considered. My team was vaguely thinking about buying an old, used one, but it was a dream.
Hope that's helpful/interesting!
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 06-11-2009, 02:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Build Your Own CNC Machine - book
No $800 CNC can make parts very accurately or quickly. But if you have the patience, you can turn out some REALLY cool stuff, that you could not by hand, or manual machining. That router would not be sufficient for aluminum, but would certainly be useful for plate work from plastic and wood type materials. I started to build one, but bought a small knee mill instead.
Anyhow, if a team has the time and the money, building a CNC is certainly a fun project. Even if you can't use it to make parts for the robot, you can still make signs, gifts, and things. And you can always continually improve and redesign the machine once you get it going.
If anyone wants to learn how to build a lathe from melted down soda cans and engine pistons, take a look at David Ginger's line of books.
Unread 06-11-2009, 03:20
RoboMaster's Avatar
Yeah, this kind of a CNC probably wouldn't be top-quality. And it wouldn't be able to cut metal. That's the big deal. But you're right, it would be a great project.
However, at least for my team, we already have a big "CNC/shop bot" for our school. It's just not super great at cutting metal. So we don't really need another machine to cut wood.
Unread 08-11-2009, 20:43
DonRotolo's Avatar
Back to humble
FRC #0832
I disagree with both of these statements, based on personal experience.
Now, it won't cut parts Fast, Cheap AND Accurately, but it will do any two of these quite well. Often the sacrifice is Fast.
Robomaster, a wood router with carbide bits will easily and happily go through Aluminum, as much as you want. Again, not fast.
I built a similar machine several years ago for about $400, intended to be sued to drill out Printed Circuit boards. But, it is a full 3-axis CNC machine, with an envelope of about 11 x 11 x 4 inches. I used a Dremel tool instead of a router, and the entire machine was about 1/3 as "robust". But I can form aluminum parts with it - albeit very, very slowly. For example, a 4" AndyMark aluminum wheel might take 8 hours to produce. The limiting factor is what the Dremel can bite off in one pass - about 10 thousandths. So an inch of depth takes 100 passes - and the table moves at 0.1" per second when cutting like that. (It moves a lot faster in PC Drill mode...). My machine has 0.00025" precision and 0.003" accuracy over 10 inches.
We used a wood router to cut out pockets in our pit cart frame in 2005. It was made of 3/16" 6061 aluminum. We used a plywood template, a pre-drilled hole to start, and we cut out a 8"-ish triangle from the sheet in about a minute. Plain wood router with a carbide bit, about 25 of those triangular holes were cut. (Gloves, full-face shield, hearing protection and other protective gear were mandatory)
So, taking both those personal experiences together, I can easily see that machine in the OP cutting aluminum with 0.001" accuracy, assuming someone builds and adjusts it very carefully.
Unread 09-11-2009, 11:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'd say this CNC is ideal for anyone who wants to make transmission sideplates out of 1/4" thick lexan and an inexpensive automated tool.
I can't think of anyone off of the top of my head who'd ever do that though
GitHub
Unread 09-11-2009, 12:21
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
If you are interested in homemade CNC stuff, this is the place to look around:
http://www.cnczone.com/
There are quite a few "build" threads that document a complete project.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Make your own CNC whytheheckme Technical Discussion 8 25-07-2007 02:13
Build your very own, VAN DE GRAAFF GENERATOR! 3DWolf Chit-Chat 2 15-02-2007 12:42
Build your own Arc Welder! Adam Richards Technical Discussion 4 23-09-2006 16:22
How-To: Build your own CNC machine David Kelly General Forum 1 29-06-2006 23:34
Build Your Own Robot Kit Rich Wong Robotics Education and Curriculum 2 30-12-2002 20:50
