Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Unread 07-11-2009, 04:37
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
15T CIM Shaft Pinion Gear (DeWalt project)
As an offseason project I bought a few DeWalts and have been working on an updated NBD type transmission. My goal is to take the original idea but morph it into a direct drive system (similar to this 1213 setup, but without removing the first stage of the DeWalt transmission). Long story short, I'm looking for a 15T spur gear/pinion with an 8mm bore and 2mm keyway so it can be mounted to the CIM shaft and plugged directly into the DeWalt tranny without modification.
Has anyone done this? If so, any suggestions, and in particular, who sells gears like this? SDP-SI seems to have the best selection, but they don't have exactly what I'm looking for. Also already checked: McMaster, Boston Gear, Small Parts, Martin Sprocket, Google, etc.
Help: Bevel Gear Mounted On CIM Shaft? 854 bears Motors 16 24-07-2009 13:50
CIM Pinion issues in Toughbox GUI Technical Discussion 9 17-02-2008 15:53
Dual CIM Dewalt??? Joe Johnson Motors 4 30-01-2006 09:49
Chiaphua Motor Pinion Gear Joe P Inventor 0 27-02-2002 15:48
