[FTC]: Labview - Servos
Second year in FTC, last year did all programming in NXT - easy to learn, just not functional enough. Now trying to work in Labview, got to get it figured out to teach my students enough to get going.
I can't find enough good examples for labview to help. I'm stuck trying to figure out how to program the servos to be controlled with either the joystick or buttons. I can figure out how to go to a specific point if a button is pressed, but if I wanted to hold button down to move one way. If anybody could send me a screen shot or sample program it would help greatly. Getting short on time. Working in most recent version of Labview. Thanks. |
Re: [FTC]: Labview - Servos
I created a simple VI that shows you one way to accomplish this. I leave it to your to modify it so it fits into the templates.
http://www.chiefdelphi.com/forums/at...d=125796519 7 You can add this VI to your block diagram by saving the image to disk and dragging the image file into your block diagram |
Thank You very much, that helped a lot.
| [FTC]: Bluetooth Problem with LabView/FTC Controller Station | James Dowd | FIRST Tech Challenge | 8 | 27-10-2009 10:40 |
| [FTC]: Tips page on using FTC Encoders with LabVIEW | PhilBot | FIRST Tech Challenge | 7 | 27-01-2009 14:00 |
| Labview Servos | quizbiz | NI LabVIEW | 5 | 09-01-2009 08:48 |
| [FTC]: [FTC]: Can any one explain to me just how powerful the servos are? | sullivan_owns | FIRST Tech Challenge | 19 | 02-12-2008 16:06 |
| [FTC]: First problem with FTC and LabView.....? | PhilBot | FIRST Tech Challenge | 5 | 07-11-2008 10:36 |
