Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
Unread 25-11-2009, 13:26
Iconē Iconē is offline
Iconē is an unknown quantity at this point
Dynamic Memory
Hello,
is it possible to allocate dynamically memory using the intelitek easy c? While programming C in windows you use malloc and free, but those are declared in the standart windows header (stdlib.h), so they wont work. Are there any similar commands/functions in easy c ?
And my second Question. Is there in easy c a function like GetTickCount in windows? Its a function which returns the milliseconds since the PC was started.
edit: Sry i've post it in the wrong forum, maybe a moderator could change this thank you.
Thank you for answering!
Greets Iconē
Dynamic memory MC18 Cadyyan Programming 3 18-08-2009 17:15
Dynamic Memory Allocation Woes slavik262 Programming 7 12-02-2008 16:15
Dynamic Tables in PHP FRANK(WGH) Website Design/Showcase 12 09-07-2007 16:07
IFI Dynamic Debug Tool fowlerm Programming 0 25-08-2005 16:18
Dynamic Debugging Tool MarkVH Programming 5 04-02-2005 18:09
