| View Poll Results: Which did your team use? | |||
| Victors |
54 | 65.85% |
| Jaguars |
48 | 58.54% |
| Multiple Choice Poll. Voters: 82. You may not vote on this poll | |||
Re: Speed Controller Preference
Team 1245 used Victors, mainly because our Jaguars burned out. Victors have higer overall output, but Jaguars have a smoother control curve.
The max current specifications for the two controllers is based on the specifications of the FETs used and refers to the continuous current. (The Jaguar uses a FET that is slightly better in this regard) In both controllers and on our robots, current in CIM motors can achieve 129 amps in stall. There is nothing that limits that current, including the breakers (assuming wiring is not undersized or lengthy). The breakers will pass nearly 200 amps for short bursts without tripping. The Jaguar has implementations that make it more linear at lower throttle values (primarily due to it's higher switching frequency) and it has a slightly lower series "ON" resistance due to the FETs used. However, these differences may not be evident in your implementation. (For the price of a search, you will find a long discussion on this subject elsewhere on this forum) For both controllers, full throttle means they are supplying the full battery voltage to the motor they are controlling. There is no modulation of the output at full throttle. The Jaguar does contain a small resistor that is used for current sense, it is equivalent to 6 inches of #10 wire. There is a voltage drop across this resistor that can limit the available supply voltage at higher currents and the current sense may cause the Jaguar to interrupt current flow for a short period of time. Last edited by Al Skierkiewicz : 09-12-2009 at 08:26. |
I thought there was a teensy bit of time where the Jaguar output is shut off even when at a nominal 100% output. Something to do with recharging a capacitor that keeps it on? I suppose it doesn't count as "modulation", though.
We used the Jaguars where we wanted fine control (drive and shooter) and the Victors for on/off (lift belt and turret).
Our team used victors for the competition. 2 for drive and one for turret rotation. Also a spike for the compressor. This year, we plan to use Jaguars as we got them working on our robot for drive. If we are feeling adventurous and we have enough, we will also use Jaguars for other things we need.
Our team used all jaguars this year and I was pleased with both their performance and price. The only issues that our team had with the jaguars was, our jaguar that controlled the motor that moved our spiral which moved the moon rocks to the top, stop working in the forward motion twice. Unfortunately this happened in the finials causing us to lose a match. The weird part of this is that the jaguar stilled worked in reverse as well as the other functions, the only thing that did not work was the forward motion. When we opened them up on both occasions we found that the circuit board had melted in one spot near the fan. We sent them back to Luminary micro for analysis but we have not herd any thing back. Our belief is that it something unique about the way we had the motor set up and the amps it drew. Other then the problem above we had no problems and all the original jaguars are still on our machine. I would suggest that teams start using jaguars if they have not already. I also look forward to exploring the new features that we will be evadible this year.
Matthew Simpson Team 75 VP |
4 Jags, 4 Victors. The Jags were upside down underneath the electronics board and powered the 'twitch' drive we had. We had zero issues running full foward to full reverse in less than a second when the twitch modules changed positions. We still used clear nail polish to keep the PWM's though
The Jaguar Failure Analysis report can be found here |
| FRC Robot Controller/Speed Controller | RoarRoar | Control System | 3 | 17-01-2008 10:41 |
| Controller Speed programming | team877 | Programming | 4 | 14-01-2008 00:56 |
| speed controller max speed | Team 668 | Programming | 15 | 13-02-2005 14:05 |
| Speed Controller | Megas_xlr | Control System | 3 | 18-01-2005 15:41 |
| Speed Controller | Megas_xlr | Electrical | 3 | 18-01-2005 15:41 |
