Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 30-11-2009, 20:25
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Rookie Year: 2007
Straberrie will become famous soon enough
Gyro Programming
Hi, how are you?
I am trying to get gyros to work and I never programmed the sensor before, so I made use of the FIRST programming guide to implement gyros in the autonomous period.
Gyro *gyro;
gyro = new Gyro (1);
gyro->Reset();
gyro->SetSensitivity(.005);
float angle = gyro->GetAngle();
myRobot->Drive(-1.0, -angle / 30);
Wait(4.0);
According to the guide, the above should have corrected the robot's path and set it to match the heading of the original angle. Since the original angle was 0, it should have went straight.
However, when we tested it on the robot, it immediately made a sharp turn.
In order to see what is happening with the angle values, I created an if statement
if (angle<0.5)
myRobot->Drive(1.0, 0.0);
Wait(0.0);
else
myRobot->Drive(0.0, 0.0);
Wait(0.0);
And it stood, I switched the statements around, and the robot didnt move either. So, I am wondering what I did wrong and how I can make the robot follow a straight path.
Any help would be appreciated,
Thank you!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 30-11-2009, 22:20
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Gyro Programming
Code:
if (angle<0.5)
Wait(0.0);
else
Wait(0.0);
if there is any sort of noise, or movement of the robot,
then the angle will be larger then 0.5,
when that happens, the robot will just sit where it is without moving
( like you said)
What I would do is make a PID controller (I don't know how to use WPI's)
sortof like this:
Code:
float desiredHeading = 0;
float speed = 0.5;
const float P = .5; // You will need to tune these values
const float I  = 0.0; // as they are just made up
const float D = 0.0;
float headingIntegral = 0.0;
float prevHeadingError = 0.0;
void autonomousPeriodic()
    float heading = fmod(gyro->GetHeading(), 360.0); // limit to + - 360 // EDIT: forgot the denominator
    float headingError = (desiredHeading - heading);
    headingIntegral += headingError;
    float headPID = (P * headingError) +
                              (I * headingIntegral) +
                                  (D * (headingError - prevHeadingError));
    prevHeadingError = headingError;
    myRobot->TankDrive(speed + headPID, speed - headPID);
The speed variable is the forward movement that you want
The real advantage of this method as opposed to the wpi example is that you can set any heading you want
(At least within the range of - 360 to 360)
Just remember to tune the PID
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 01-12-2009, 04:56
Straberrie's Avatar
The Plague
AKA: Rebecca
Rookie Year: 2007
oh wow O.O XD Thank you so much!!!
Unread 01-12-2009, 22:15
biojae's Avatar
You are quite welcome.
I fixed a small error in the code, i forgot the denominator in the fmod operator.
(360, by the way)
gyro captainking General Forum 4 03-02-2008 22:25
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Gyro magical hands Programming 2 14-01-2005 20:57
gyro odin892 Programming 0 08-04-2003 09:59
