Go to Post As usual, I mistakenly look for a technical solution to a social problem. - MrForbes [more]
Unread 07-12-2009, 01:14
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
type-casting fixed-point to string
Is there a known issue with type-casting a fixed-point number to a string on the cRIO?
I'm trying, and it turns out empty data. However, it works fine on my computer.
Any ideas?
-- Marshal Horn
Unread 07-12-2009, 07:21
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Re: type-casting fixed-point to string
Any ideas?
Which Language?
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 07-12-2009, 07:33
Fixed point numeric support went into LV just a few years ago, so it may very well be a bug. It may also be that you are doing something few have tried. Please attach a simple VI showing the issue.
Greg McKaskle
Unread 07-12-2009, 19:00
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Here's an example.
It looks like the "flatten to string" function works, though.
-- Marshal Horn
Unread 08-12-2009, 08:29
If I run the attached VI on LV 8.6, both flatten and typecast produce the same values -- for the half dozen I've tried. If there wasn't a specific value that failed, it looks like a bug in 8.5 that was corrected.
Greg McKaskle
Sand casting? Madison Technical Discussion 12 27-06-2009 10:24
Type casting Fat Alex Programming 0 17-02-2005 13:52
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 27-02-2004 07:58
Carbide / Hardening / Casting Veselin Kolev Technical Discussion 4 22-01-2004 16:53
