Go to Post You don't want down time during build, eh? - dtengineering [more]
Unread 12-07-2009, 09:32 AM
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
windriver2010
I'm having problems with downloading an older C++ project to the new WindRiver of 2010
Can anyone help?
The build process just hangs there, no matter what you do. The workspace is in the same position and it can't build the source code and the necessary .out files. We used the guide. PDF, I think, some were we done some thing wrong.
We received a warning: setup\bin\ Proxy license can't be located.
Our question is if we should copy our old 2009 C-code some were, we coped all the folder of our code to windriver \Workspace
This is really stopping us from letting us do ANYTHING. Any help would be much appreciated.
Team 1946
TEAM 1946-Tamra
Unread 12-08-2009, 11:45 AM
jalburty jalburty is offline
Joe Alburty
AKA: Joe Alburty
FRC #1763 (Paseo Pirates)
jalburty will become famous soon enoughjalburty will become famous soon enough
Send a message via ICQ to jalburty
Re: windriver2010
It sounds like you've moved your source code files to another location on your hard drive. If so you might need to redirect WindRiver WorkBench to the new location. That or put them back where they were.
The simplest way I could think of to keep last year's code was to copy the .cpp files we changed to an archive folder. After doing this I've continued making changes to the old files in WindRiver.
Unread 12-09-2009, 01:53 PM
yara92's Avatar
AKA: Mohamed
Re: windriver2010
Hi Joe
Thank you for your advice, that exactly what's happened. It took from me 3 hours. But it is nice
Using a Run/Debug Configuration in Workbench works perfect. This loads the program into the cRIO RAM memory and allows it to run either with or without the debugger. When the robot is rebooted, the program will no longer be in memory.
Deploy the program through the FIRST Downloader option in Workbench NO COD
I figure that today when I open Window preferences to choose the file
It is working with Deploy
Team 1946
mohamed
TEAM 1946-Tamra
Unread 12-09-2009, 03:40 PM
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
Team Role: Leadership
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: windriver2010
This thread only applies to beta teams, correct?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 12-14-2009, 12:44 PM
yara92's Avatar
AKA: Mohamed
Re: windriver2010
Yes it is
TEAM 1946-Tamra
