Go to Post ...he's acting like a programmer whose code is compiling...:yikes: - EricH [more]
Unread 11-12-2009, 19:01
ctcw ctcw is offline
FRC #1540
ctcw is an unknown quantity at this point
Problem with Joystick Throttle
I am having a problem with the throttle on my team's joystick. We recently switched from C++ to Java and everything seems to be working fine except for the throttle. It seems to be returning a value of 0.8984375 no matter what it is set to. For instance,
System.out.println(joystick.getThrottle());
returns
[cRIO] 0.8984375
every time. Has anyone been experiencing a similar problem?
Thanks.
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Problem with the joystick Asmos NI LabVIEW 5 23-01-2009 09:40
Help with programing saitekx36f joystick and throttle sonicx059 Programming 4 21-01-2008 20:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
joystick problem archiver 2000 12 23-06-2002 23:08
