Go to Post Logic has no place here whatsoever. - ThamiorLianodel [more]
Unread 13-12-2009, 14:17
ThisAintJeff's Avatar
ThisAintJeff ThisAintJeff is offline
FRC #1591 (Greece Gladiators)
ThisAintJeff is an unknown quantity at this point
Send a message via AIM to ThisAintJeff
Reprogramming the Box
alright, so one of our mentors mentors another team in our county as well, so he brought our control board over to their team to use with thier robot. on friday we got it back, but the team in it has been switched from 1591 to 3015 (obviously so it could work for that team). how do i change it back? is it something with the box's IP adress?
Unread 13-12-2009, 14:20
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Re: Reprogramming the Box
If you mean one of the old IFI controllers than there should be some switches that are labeled team number that you can adjust. If you mean the cRio, which is more likely, than you need to follow the instructions in the manual located at http://www.usfirst.org/roboticsprogr....aspx?id=14532.
Edit: It is in chapter 5, the cRio instructions start on page 7.
- Arizona North
Unread 13-12-2009, 14:31
thank you for the help! i got it working now
[OCCRA]: Mounting the andy marks tough box to the kit box SwindyWBcapt OCCRA Q&A 1 05-10-2009 16:18
pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. bubbablahmon Extra Discussion 15 22-01-2008 09:40
Can you mount the tires directly on the gear box? free_rider_151 Motors 9 13-01-2007 09:04
What was in the 5th box that the rookie teams got? Jack21 General Forum 3 12-01-2004 03:55
Weird Moving-Box (or any Big Box) uses Kristina Chit-Chat 5 25-06-2002 17:19
