Go to Post Thanks Autodesk! - Al Skierkiewicz [more]
Unread 17-12-2009, 11:17
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
Xbox Controller
I knew that the xbox controllers aren't able to communicate with the DS. But now that the DS is replaced with a laptop, would that open the door to driver required controllers?
Unread 17-12-2009, 13:20
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Re: Xbox Controller
As long as it's a wired-USB controller, you should be able to use it. I think one of the beta test teams successfully tried an xbox controller with the new DS.
Unread 07-01-2010, 21:23
rihan.nasser's Avatar
rihan.nasser rihan.nasser is offline
FRC #3132
rihan.nasser will become famous soon enough
Exclamation Re: Xbox Controller
yeh....... i heard they made it work pretty easily
i think they were how to fix the configuration
of the two joining up
Unread 08-01-2010, 13:55
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Xbox Controller
Yes, they did. You simply need to install the Windows drivers for it from Microsoft.
Unread 11-01-2010, 22:17
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
Rookie Year: 2010
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: Xbox Controller
We are thinking about doing the same thing.
Does anyone have any input has to special uses (ik the xbox controler can sense different amounts of pressure on the buttons)
Unread 11-01-2010, 22:39
TD-Linux TD-Linux is offline
FRC #2530
TD-Linux is on a distinguished road
Re: Xbox Controller
The reason Xbox 360 controllers did not work with the previous DS is because they use a nonstandard HID protocol. This year, as long as you have DirectInput drivers for your pad installed, they will work.
Unread 12-01-2010, 20:37
FRC #3132
Thumbs up Re: Xbox Controller
i heard they are nearly expensive even on E-BAY
but i know they are easy to work
Unread 13-01-2010, 14:17
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
Re: Xbox Controller
The xbox controller can't tell how hard you are pushing the buttons. It can only tell how hard you are squeezing the triggers and movin the joysticks. Maybe I should make a class for the xbox controller with better labeled buttons, so you can say the "a" button instead of a number.
Unread 08-02-2010, 21:05
Rafael Vasquez Rafael Vasquez is offline
FRC #1245
Rafael Vasquez is an unknown quantity at this point
Re: Xbox Controller
We have the correct drivers for the computer to recognize the controller, but we can't get it to work in LabVIEW. Any tips?
Unread 30-06-2010, 13:17
MCeGEAR MCeGEAR is offline
FRC #1243
MCeGEAR is an unknown quantity at this point
Re: Xbox Controller
Now are we talking about the xbox 360 controllers or the xbox original controllers? Because the original controllers are fairly cheap and very easy to mod to work for windows xp, at this moment i am using one as a mouse, but I have yet to see one used for a controller for their robot.
Links on how to use a Xbox controller on XP and Driver download
http://jusfocuz.vox.com/library/post...ro-guitar.html
Note: the yellow wire is not used in the Xbox controller wire.
Xbox 360 controller LabView CJBrick General Forum 12 17-12-2008 13:58
xbox controller borabora Technical Discussion 8 06-02-2008 21:52
xbox controller PrincessJae Programming 4 06-02-2008 17:18
Xbox Controller? ScottieDo555 Technical Discussion 24 29-01-2008 16:24
Regular Xbox Controller...HELP! lostandconfused Control System 1 13-02-2007 14:29
